Stripped thread toes shifter
Old May 7, 2013 | 11:33 AM
rome304's Avatar
rome304
Default Stripped thread toe shifter
Buddy keeps tightening toe shifter 07' flhx threads on shaft must be stripped does anyone know part# and what it will take to replace shaft that holds heel and toe shifter thanks.
Old May 7, 2013 | 11:43 AM
mkguitar's Avatar
mkguitar
he may get temporary relief by swapping the heel and toe shifters on the shaft...that way you get 1 set of "sharp" teeth against a set of "dull" teeth, rather than 2 dulls.
anything that can be done to minimize slop will help- incl wrapping a teflon tape in there.
try that first.
mike
Old May 7, 2013 | 12:17 PM
collin's Avatar
collin
Why would they make the shifter out of a harder material than the shaft? You might be able to drill and tap the shifter to accept a set screw, then mark the location with the set screw and grind a small flat on the shaft.
Old May 7, 2013 | 12:19 PM
kyote's Avatar
kyote
just replaced my shaft..don't recall the part # but it was fairly cheap for a harley part..only about $18
Old May 7, 2013 | 12:34 PM
slimvela's Avatar
slimvela
Replace shaft and shift lever so the old lever doesn't screw up the new shaft...don't ask me how I know.
On another noote, use heel eliminator then use heel lever for toe shifter.
Old May 7, 2013 | 04:44 PM
big cahuna's Avatar
big cahuna
last year a friend of mine brought his "08 Ultra classic over for me to take a look at his heel shifter that fell off. The screw that pinches the lever together, looked like it was loose and had the threads flattened on one side. He Bought a new screw and I put a dab of blue lock-tight on it to keep it from happening again. Been about a year and it hasn't loosened up. Should have been done at the factory.,,
Old May 7, 2013 | 05:15 PM
toothmansteveb's Avatar
toothmansteveb
Best to replace everything.
Old May 7, 2013 | 05:31 PM
glebo's Avatar
glebo
tell him to stop stomping on the shifter...seen to many folks whack that thing...
Old May 7, 2013 | 06:16 PM
0ldhippie's Avatar
0ldhippie
I love my thing whacked...
Old May 7, 2013 | 06:52 PM
mikelikesbikes's Avatar
mikelikesbikes
Yeah, that and be sure to use blue loctite. Also when removing the screws they must come out completely.
