Wire covers
Old May 8, 2013 | 05:49 PM
FL-kruzen's Avatar
FL-kruzen
Default Wire covers
I had to replace a bad start/run switch on my handle bars on a 2001 EGC. In doing so, I had to split the wiring harness to solder in the new switches. Now I have the wires running from the right handle bar switch house to the fairing and the wires are wrapped with black tape. Is there something better I can cover the wires that looks more professional? Any ideas or suggestions?
Old May 8, 2013 | 06:50 PM
gbear's Avatar
gbear
you could try locating some heat shrink tubing that comes in various lengths. put as much heat to it to shrink it as tight as you might want it. comes in various colors as well. good luck.
Old May 9, 2013 | 06:24 AM
FL-kruzen's Avatar
FL-kruzen
Thanks. But I had to tap into 4 out 20 wires. Can't use heat shrink on existing wires unless you cut all 20 and solder them back together.
Old May 9, 2013 | 06:40 AM
collin's Avatar
collin
You could try something like this, it's made in black also
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
Old May 9, 2013 | 07:06 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
There's heat shrink tape also.
Kokes58
Feb 15, 2015 12:49 PM
berndog
Shovelhead
May 4, 2012 07:39 PM
rodney123456
Mar 27, 2012 04:29 PM
mattlal
Aug 2, 2011 11:01 PM
Dyna2007
Dec 27, 2009 07:34 PM
