Phase 7 LED light
Old May 8, 2013 | 08:12 PM
sammiew's Avatar
sammiew
Default Phase 7 LED light
I installed my Phase 7 headlight and was going to adjust it down some to start with but when I backed the adjustment screw out one round it made the headlight screw and headlamp loose. It would rattle around if I done this. Am I doing something wrong? It's on a 2012 FLHX.
Old May 8, 2013 | 08:18 PM
Bushy's Avatar
Bushy
stock removal to Phase 7 was plug and play... I installed mine in a few , I also opted for the addition ring to offset the difference in depth... adjustments are easy as long as you only loosen the out ring, spin it to the top and the adjust.. turn outer ring back so adjustment screw is on bottom and tighten, hope this Helps
Old May 8, 2013 | 09:32 PM
sammiew's Avatar
sammiew
I still have the outer chrome headlight cover removed so I can adjust the headlight if needed. The screw on the top of the headlight to make adjustments up or down is the one if you back off to lower the beam on the light gets loose only with one full turn out. Not any adjustment to make the light beam lower.
Old May 8, 2013 | 09:42 PM
Bushy's Avatar
Bushy
you have to install that ring.... that holds it in, the other ring is more cosmetic
Old May 8, 2013 | 10:31 PM
my67pnycar's Avatar
my67pnycar
I have a set waiting on me when I get back from this deployment, I can't wait to see the improvement they are going to make.
Old May 8, 2013 | 11:49 PM
PassRusher75's Avatar
PassRusher75
You will love them.
Thank you for your service!
Old May 8, 2013 | 11:52 PM
my67pnycar's Avatar
my67pnycar
Thank you.
Old May 9, 2013 | 12:14 AM
traylestrat's Avatar
traylestrat
HD's are plug and play and awesome. I don't think for one nano second that visibility is an issue, I just don't think about it. And I ride every night. The so called horizon effect...don't even notice it now. Worth every penny.
Old May 9, 2013 | 08:22 AM
Bushy's Avatar
Bushy
I did the Truck lite head light and passing lamps, LED signals front and rear and Brake Light... Volt meter never goes below 16... they are the cutting edge,, FYI those green signs on the side of the road> when you approach them they turn on like a jumbo tron with these light!!! amazing
Old May 9, 2013 | 08:50 AM
euchre98's Avatar
euchre98
Wheres the best place to get the Truck lites now?
