4.5" passing/spot lamp lens
Old May 9, 2013 | 09:52 PM
Mike_M's Avatar
Mike_M
Default 4.5" passing/spot lamp lens
So I managed to crack the lens of one of my passing lights (spot lamps?). It looks like it took a hit from a rock and cracked the lens completely.
I'm pretty sure it's not a sealed beam, since it's still working (and the cracks definitely go all the way through).
My question: Is it possible to just replace the lens? Any idea how much one costs? Is it something that the dealer will have in stock?
Should I just bite the bullet and get the Trucklite passing lamps? (wasn't planning on that expense right now)
Thanks!
Old May 9, 2013 | 10:16 PM
Nute's Avatar
Nute
Go to shopronniesharleydavidson.com and using the parts finder catalogue you can look up the exact part you need and it's part #. I did a quick check and not knowing your actual bike model 96 vs 103 etc. and found found what you would be looking for. I assume the passing lights would be the same for all Electra Glide but best to make sure you get the one listed for your bike. You can purchase just the lens or the whole lens assembly.
Old May 9, 2013 | 10:59 PM
Mike_M's Avatar
Mike_M
Thanks!
Looks like it should be an easily replaceable item and isn't even that expensive at ~$40.
Cheers
Old May 10, 2013 | 04:00 AM
my67pnycar's Avatar
my67pnycar
Its not sealed. You could fleabay it, might come out cheaper.
Old May 10, 2013 | 06:55 AM
SBates08's Avatar
SBates08
I just bought a set at the new Panama City Harley Dealer last weekend. Bout $78 for the pair. Plug n play.
Old May 10, 2013 | 07:14 AM
CashMoney's Avatar
CashMoney
If you go with the truck lite ones check with your local Peterbilt or big rig dealer. The dealership I get 90% of my parts from got me mine for around 80 a piece if I remember right. Instead of buying the adapter plug for the new style light I used a repair plug for a gm fog light I got from an AC Delco parts store to update it to the newer Harley plug
Old May 10, 2013 | 12:36 PM
Ultra103's Avatar
Ultra103
What year is your bike? I had one basically explode on the 2012 and the dealer actually ADMITTED they have been having problems with the newer ones. They had to change more than just the lens (the trim or something too).
They fixed it on the spot at no charge.
leadman
Jan 15, 2015 09:27 AM
jimmy28
Touring Parts
Jul 21, 2012 05:44 PM
JPstreetglide
Touring Parts
Sep 1, 2011 11:09 PM
JeffreyB
Sep 27, 2007 09:00 PM
mcpastor
General Topics/Tech Tips
Apr 16, 2006 06:05 PM
