New Onset Pinging
Old May 13, 2013 | 02:38 AM
Watch Guy's Avatar
Watch Guy
Default That's exactly right
Originally Posted by TUCCI
Exactly what the situation when mine started. Even after purchasing a PCV with a map from Fuel Moto, requesting a map for that exact problem there was no solution, in fact the pinging was worse because of the advanced timing tables in the map. It wasn't until I partnered with a forum member and he helped me to understand that retarding the timing in the areas I felt the ping is and was the solution to the problem. So, yes your likely going to need a tuner that allows you to get into the timing tables (you choose which one). Then methodically work the areas the pinging is the most prevalent and eradicate it with retarded timing.
I got a map from Jamie at F.M. and experienced pinging midrange and beyond. Looked into the map and found mostly 3 and 4 degrees advance timing. I reset all the timing to zero and have no ping issue at all any more. Seems OEM cams aren't really in need of any advance unless the compression is increased. Bad gas can be a problem but it generally dissipates after 2 tanks or so.
El Chiguete
Mar 27, 2017 05:54 PM
kylebryan
Sep 9, 2015 09:58 AM
marknett
May 5, 2014 01:51 PM
frenchbiker
Jun 4, 2012 08:16 PM
Fear Night
Aug 4, 2009 09:32 AM
