Inflating tires
Old May 14, 2013 | 02:30 PM
  #31
fastwalkin's Avatar
fastwalkin
Check mine before every ride, sure it's a pain for a couple of minutes. I believe in a PMS (Preventive Maintenance System) rather than DC (Damage Control) . All it takes is ONE screw/nail/piece of metal to screw up your day. I gotta lay down on the ground to comfortably check and fill if needed..i have a slime pump that works well plugged in to the bikes 12 volt dc plug. Check and fill five minutes,price FREE...ride all day long no worries, Priceless ! cheers
Old May 14, 2013 | 03:02 PM
  #32
Hausguy's Avatar
Hausguy
It's part of my routine like checking bulbs and blinkers before every (mostly) ride. I just installed the 90 degree valve stems today along with new tires so checking will be even easier.
Old May 14, 2013 | 03:26 PM
  #33
Unheilig's Avatar
Unheilig
Originally Posted by JohnnyC
First off welcome to the Forum. I don't think I have spoken directly to someone in Russia ever before. It's interesting to have riders from around the world here. Where in Russia are you located?
Thank you! I am from Moscow.
Old May 14, 2013 | 03:44 PM
  #34
Unheilig's Avatar
Unheilig
Originally Posted by fastwalkin
Check mine before every ride, sure it's a pain for a couple of minutes.I believe in a PMS (Preventive Maintenance System) rather than DC (Damage Control) . All it takes is ONE screw/nail/piece of metal to screw up your day. I gotta lay down on the ground to comfortably check and fill if needed..i have a slime pump that works well plugged in to the bikes 12 volt dc plug. Check and fill five minutes,price FREE...ride all day long no worries, Priceless ! cheers
Golden words!
Originally Posted by cass
I'm getting ready to put my "summer" air in, replacing the winter air. just kidding of course. i check every once in awhile if it feels a little funny. most of the time its just road condition, not low air. i had the sensors on my yamaha and on my other Harley, kind of a pita after the novelty wore off. i found that the batteries could/would go a little faster than i would have liked but it was cool to see the tire temps and the pressure increase as the pavement heated or the miles added up.
Oh да, Привет и Добро пожаловать на форум
I think there is no point in spending $ 300 on tire pressure sensors, these sensors during inflation still have to unscrew.
Originally Posted by EasTexUltra12
I'm finding most of these replies pretty amazing. I check my tires once a week. Since I drive a company truck, that's usually Saturday before a ride. With the Spring we've had this year with the wide temperature swings, pressure can and will change drastically. If it's 45 one week and 80 the next, tires will be 3-5 psi high. If it's back to 40 the next week, tires will both be 3-5psi low. No way would I feel comfortable only checking a couple of times a year.
Ride Safe
David
I was just curious opinion, the conclusions for myself, I did. I will check as often as tested before.
I learned about the 90 degree valve stems, I was told that it is possible imbalance wheel. May be they are mistaken, but for installing i need to disassemble the wheels, at now i do not want to do this.
Old May 15, 2013 | 08:11 AM
  #35
canaan canam's Avatar
canaan canam
morning gentelmen,
new rider and i have been having thoughts running about air pressure.
owners manual says 34 does that mean put 36 lbs in tires
or do i use the max on side wall and add 2 lbs
dealer made a big deal about nitrogen in the tires when i bought it .will this make a difference and if i need to add should i run it 20 miles one way or just add some air
i run about 5 lbs over in my cars but im so new to bikes is to much air a bad thing
thanks
Old May 16, 2013 | 07:38 AM
  #36
mikelikesbikes's Avatar
mikelikesbikes
Originally Posted by canaan canam
morning gentelmen,
thanks
It would seem to me that the dealer you are at sells nitrogen? All hype if you ask me. Keep your tires at 40 and you are good to go. Well, I am talking about a bagger and what I remember from the service manual. Your options may vary.
Old May 16, 2013 | 07:54 AM
  #37
EasTexUltra12's Avatar
EasTexUltra12
Not necessary to remove tire for 90* stems. I have a screw on 90*adapter that stays on my back tire all the time. It does make checking the air much easier, and there are no balance issues that I notice. I do use dyna beads in it so that should take care of balance issues. However, I used the same 90* screw on adapter on my OEM tire with it wheel weights and still didn't notice any problems. The screw on adapter is a bit ugly, but unless you're looking, you can't see it on the back tire anyway. I don't think I'd use it on the front but it's pretty open and easier to check anyway.
Ride Safe
David
Old May 16, 2013 | 10:03 AM
  #38
DPelletier's Avatar
DPelletier
morning gentelmen,
thanks
Nitrogen is snake oil as far as automotive and motorcycle tires go; save your money. Personally, I'd question the knowledge and/or morals of any dealer spouting off the nitrogen bs to me.
DAve
Old May 16, 2013 | 10:20 AM
  #39
EasTexUltra12
DAve
I used to think so too. We've got 2 F-250 Super Duty pickups that we use for shop use and all deliveries. One has nitrogen in the tires, and the other one doesn't. The one with nitrogen has never needed any air in the year the tires have been on the truck. The one with air seems to need some when we take it in to have the oil changed.
I still wouldn't use it on my bike. No really valid reason, I just like the peace of mind of knowing my tires are correct for the day's ride. But I will use nitrogen in my cage tires when it comes time for replacement.
Ride Safe
David
Old May 16, 2013 | 11:43 AM
  #40
TheGrandPoohBah's Avatar
TheGrandPoohBah
It is recommended to check tire psi before each ride, of course, but honestly I check mine every week or two. Much easier on the lift or dolly where you can spin the tire and exam better - but we can't let that stop us! At home, sometimes I will roll the 'King to get the rear stem down, I lay down a big piece of cardboard on the right side of the rear wheel, and lay on it to check the rear psi with my HD Gauge with the flex hose and 90 end. I keep that piece of cardboard leaned against the wall just for that purpose.
Tire Pressure Monitoring Systems (TPMS) are a good idea. I have them on my other vehicles, but it is at first a little pestering to see how much your psi varies on the go. Some vary is OK, but some models allow for alarms that could serve you well if something goes wrong. Most bike models also show temp.
Nitrogen - as others have said, reduces the "vary" in psi, but unless you are dealing with extreme temps high or low, probably not a must have on our bikes. But to each their own.
After all, the air we breathe is approx 80% nitrogen - thats 4/5ths - do you really think they vac/purge your tires to give you 100% nitrogen? I doubt it.
BTW - TPMS systems for motorcycles are out there on the web, Amazon for example, most give "instant" readings, few give "continous" readings with alarms. +-$130.00
FWIW.
Ride safe!
