Need some help! No running lights....
Old May 15, 2013 | 05:40 AM
Flintshooter54's Avatar
Flintshooter54
Check that bracket. Is a mounting screw sticking through into a hot wire? Did you have to drill a hole and maybe cut or exposed a wire? Maybe just pinched a wire to the mounting metal. If everything worked until that last step it has to be right there at the last change. I agree as what is causing the problem is not a "stock" problem it will not be under warranty.
Old May 15, 2013 | 08:50 AM
Long124's Avatar
Long124
I thot the same thing, maybe a wire exposed ect., but there were no wires touched. I mounted the Iron Aces bracket to the speedo/tach housing which was done away from the bike. Put the bracket back on which took all of 5 minutes...easy job no wires to pinch......instag8tr keep me posted on what you find out...I'll do the same.
Old May 15, 2013 | 12:06 PM
instag8tr's Avatar
instag8tr
The service guy said the speaker wire was plugged into the headlight wire. I was like WTF!? That doesn't make any sense.
Old May 15, 2013 | 12:11 PM
skratch's Avatar
skratch
i guess that's so you could hear where you're going?
Old May 15, 2013 | 07:56 PM
Long124's Avatar
Long124
Got it figured out....The right turn signal wire was pinched between the inner and outter fairing causing a short. The thing is the fairing hasnt been off since last April and it just happen to screw up when I was doing my thing which caused a lot of looking in the wrong place...35.00 for a new part and we are back in business.
Old May 16, 2013 | 04:00 AM
instag8tr's Avatar
instag8tr
Good find . I am sure it is a relief .
Old May 16, 2013 | 11:48 AM
Long124's Avatar
Long124
Yes indeed.
Seal
Jul 19, 2016 07:01 PM
Spartanden
Jun 21, 2014 07:36 AM
FFLETCHER
Sep 11, 2012 07:07 PM
Filmy
Mar 31, 2009 10:49 AM
Voodoo
Nov 16, 2006 09:29 PM
