Most everyone feels anything under 2000 RPM is lugging, I try to run between 2200 RPM
and 3000 RPM normal riding. My bike starts to Pull good from 2500 RPM up to about
5800 RPM with stock cams and a Stage 1 set up. Guy's with the SE 255 cams can pull
down into and around 1700-1800 RPM because they have high Torque low RPM cams.
JMO (o!o)
Love this thread, I think before anyone rides off the lot they need to have a firm understanding of what lugging the motor will do to there scooter! Great thread!
JMO (o!o)
You can ride your machine any way you like. And it's very true that Idling down the road below 2K can be really smooth. But again if you are climbing a hill or passing obviously moving to a lower gear and putting the rpms in the more common range of 3K or above will prevent issues of "lugging" and will certainly give you a more snappy acceleration.
But you shouldn't be cruising 45 in 5th at 1,500 rpms and try giving it throttle. That is lugging and even if you don't need quick acceleration the load on the entire drive train is not going to blow up but it is damaging and will accumulate by exacerbating the system. May not fail now, but over time it's not the best way to operate.
And all of these comments are based on a typical machine. "Your mileage may differ."
I have a tach on my 110 engine and have gotten used to shifting at 3000K plus. I intentionally try to stay away from the bottom 2Ks. I am sure that you are not lugging over 2500 and it seems to be humming at 3K, but if you altered the bike, changed the torque range, etc. then you will have different results. No standard answer applies to all bikes with custom and stock options (obviously).
I ride a Road King, thus no tachometer. If I am cruising around town going 50-55 in 5th gear, is that lugging it? I am not talking about accelerating. When I need to speed up, I downshift to 4th.
Before I had a tach, I used go by how fast I'm going:
1-20 = 1st (go into 2nd at 20)
20-30 = 2nd (go into 3rd at 30)
30-40 = 3rd (go into 4th at 40)
40-50 = 4th (go into 5th at 50)
50-60 = 5th (go into 6th at 60)
60+ = 6th (downshift if I need to accelerate)
That's usually the low end of the spectrum, probably around 2000 rpm's after the shift.
