Rear pulley choices?
So let us look at also fitting that DD6 and play with some numbers. Baker recommend changing the compensator from the standard 24T to 28T. On a stock bike with 32/70 belt drive, that will give a 5th gear of 3.32:1, almost identical to your current top gear, with a 6th 'overdrive' of 2.89:1. Baker also offers an alternative 27T compensator.
If we fit your 66T rear pulley, but fit a 27T compensator, hey presto, we get a 5th gear of 3.25:1, very close to your current top gear, with a 6th gear of 2.83:1, very close to the 6th gear above. How does that sound?
so don't know if the 08 just adds the bowl compensator to the wheel and is fastened that way with 5 bolts and then the outer pulley is just put on there with a bearing and then the vibration is nulled by the rubber isolators inside the bowl?
the gearing sounds good to use the 66 and the 27
some say they can feel less vibration...then you also have the bearing failure...
