not charging
Old May 18, 2013 | 12:07 PM
shakrr's Avatar
shakrr
Default not charging
My regulator was bad and I installed a new one, I had 34 volts from the stator, I went to ride after the install and my meter only went to 12.6 then as low as 11.4 and one gauge started to blink [dakota digital]. my battery was fully charged [one year old]. I checked the stator wire and it ohms at .1 to .6, I check for continuity from each terminal to ground and it has continuity so is that the sign its bad
Old May 20, 2013 | 07:20 AM
kyote's Avatar
kyote
You are correct.. manual states there should be NO continuity between either test point & ground..if you do then you have a ground stator and needs to be replaced
Powerwagon64
Jun 27, 2015 05:07 PM
cskarns
Electrical/Lighting/Alarm
May 24, 2015 04:16 PM
TSD
May 2, 2014 06:15 AM
Jethro
Nov 8, 2011 04:17 PM
HoggyMtnBreakdown
Sep 7, 2011 10:19 PM
