Charging Problem?
Old May 1, 2014 | 07:00 PM
TSD's Avatar
TSD
Default Charging Problem?
I checked the voltage regulator by the manual and the way I am checking it, it test bad. Ground on battery and check to see of there is voltage at stator plug and there is. Manual says this is bad regulator. Is there another way to check it? Thanks, Tim
By the way, Fully Charged battery and no DTC's, no Check engine light but volt gauge not charging!!
Old May 1, 2014 | 07:09 PM
mkguitar's Avatar
mkguitar
do your checks for voltage AT the battery, do not rely on the in dash meter.
you should see about 14 volts or so with the motor reving at 3000 rpms por so.
mike
Old May 2, 2014 | 06:15 AM
grbrown's Avatar
grbrown
Use a proper multimeter! There are a couple of Stickies in the Tech Electrical section that should help you check.
Harbri
Shovelhead
17
May 1, 2013 09:10 PM
tundra
EVO
Aug 28, 2012 06:41 PM
StreetBobBrad
Nov 22, 2010 02:23 PM
Astro
Oct 10, 2010 07:08 PM
roaddognk
Sep 5, 2009 09:56 PM
