Front dive under breaking ?
Old May 19, 2013 | 08:30 PM
SteveMKentucky's Avatar
SteveMKentucky
Originally Posted by mkguitar
...naturally the weight shifts from the rear to the front when slowing ( just as the weight shifts to the rear when accelerating)-- ...
Mike
The weight of the bike does not shift (other than a minor amount by fluids sloshing forward). The weight of the bike does not change nor does it shift. What you're probably referring to is breaking force and torque effects from braking.
Old May 19, 2013 | 08:37 PM
KYBill's Avatar
KYBill
I had the dealer put heavy weight oil in my front forks and that cleared up the issue for me. Now if I hit a hard stop with mostly the front brake I can still get some dive but nothing significant.
Old May 19, 2013 | 09:46 PM
mkguitar's Avatar
mkguitar
No i am referring to the weight of the bike and rider shifting onto the front wheel when braking
this is motion 101.
and when accelerating the weight bias shifts toward the rear
this has little to do with which brake is used to slow the vehicle- it is the fact that the vehicle is slowing...
I hope that you mis-understood my original post.
otherwise get thee to a rider course asap.
mike
Old May 19, 2013 | 11:00 PM
0ldhippie's Avatar
0ldhippie
https://www.hdforums.com/forum/touri...rk-better.html
Old May 20, 2013 | 01:06 AM
luisan's Avatar
luisan
Ricor Intiminators and problem solved.If you follow Fabrik8tor's advice you could even improve them.
Old May 20, 2013 | 10:14 AM
jefla's Avatar
jefla
I put mixture of 60% SE/40% stock in my 09 SG. Dang near eliminated the terrible brake dive of the stock setup. Although I am not an aggressive rider, this was a very big improvement.
Old May 20, 2013 | 01:00 PM
Notgrownup's Avatar
Notgrownup
Short of modifying with Progressive or ricor Intiminators i have had good luck with new fluids every 20000 miles. Cheap and easy to do also.
Old May 20, 2013 | 01:17 PM
cobaltt's Avatar
cobaltt
Originally Posted by TexFF
My bike has 22K miles w/stock fork oil. Under normal braking the nose dives pretty bad. Will just changing the for oil stop this or do I have to use a different valving, like Ricor Intiminators? Thanks,
I recently changed my fork oil from stock oil to se heavy wt #99881-87. this is not the super heavy racing fork oil (which is not recommended). It made a huge difference on my 99 fxdwg. no more nose dive. try it out before you spend any money, you'll be surprised. good luck.
Old May 20, 2013 | 01:26 PM
bobgv's Avatar
bobgv
Get some Monotubes and bye bye front end brake dive. Just my $.02
Old May 20, 2013 | 01:42 PM
davedyna's Avatar
davedyna
Ditto, monotubes for brake diving -- they made a huge difference for me
(now I am looking for an overall better front shock system than monotubes but they sure helped in the dive department)
