stripped drain plug
Old May 23, 2013 | 10:25 AM
lionsm13's Avatar
lionsm13
Tell him to take it back to the dealer.
It's a new bike I assume?
Old May 23, 2013 | 10:35 AM
Leftcoaster's Avatar
Leftcoaster
Warranty would and should be the first thing to try. You just never know, you might end up with a new outer primary and all is golden.
Second, the MOCO seems to think all drain plugs should have thread tape or dope used on them. If that plug has an o-ring, absolutely insist that it be reassembled sans thread sealer of any kind. That's most likely the cause of the thread galling in the first place.
Failing the warranty cure you might be better off tapping threads one size larger and fitting a new corresponding plug.
Good Luck.
Old May 23, 2013 | 10:59 AM
chgofirefighter's Avatar
chgofirefighter
I did away w the stock drain plug and purchase one of these below... For $14 you can't go wrong, plus its a better plug w a better magnet, Harleys plugs are cheaply made, sad but true.
http://www.magneticdrainplug.com/Mot...l#.UZ48WeC3qK8
Old May 23, 2013 | 11:47 AM
AlaskaAviator's Avatar
AlaskaAviator
I would go oversize.
Old May 23, 2013 | 11:51 AM
Markymannn's Avatar
Markymannn
Originally Posted by hardheaded
first time the plug has been out. he said the threads came out when he pulled the plug, said it was hard coming out the whole time he was unscrewing it. i'm guessing it was installed incorrectly from the factory. i have not seen it yet,but was thinking a time sert or helicoil would be the fix. i also was thinking about a self tapping oversize drain plug from the auto parts store.
You don't think that at first he turned it the wrong way?
Old May 23, 2013 | 12:30 PM
Nute's Avatar
Nute
Take the plug to HD dealer, Napa, or some other auto parts dealer and get them to give you a replacement plug next size up from original one. Your brother isn't the first to strip a drain and won't be the last. They actually make replacements that ream the hole and cut threads as you put them in. I'd make sure there aren't any metal cuttings left behind inside the casing when new plug has been installed. Not a big deal to remove the primary chain cover.
Old May 23, 2013 | 12:33 PM
rg_dave's Avatar
rg_dave
Go down to the autoparts store and get a self tapping 1 over plug. Ran that in my streetglide for 30,000 miles after stripping my primary drain plug at 20,000 miles. Easy and worked great.
Old May 23, 2013 | 02:16 PM
oly22's Avatar
oly22
I did the exact same thing. Threads came out when I removed the plug and installed a helicoil. 15,000 miles with no problems. Unfortunatley, I don't remember the size.
Old May 23, 2013 | 04:00 PM
01fxdxt's Avatar
01fxdxt
that's what i was thinking also, but their going to say he stripped it, so not even going down that road, gonna fix it ourselves and be done with it. just kinda sucks that it happened right from the factory and he's pretty pissed about it. where's the quality control, is anybody paying attention when they are putting these things together? when i bought my new bike there was all kinds of lose stuff on it, but as so as i buy anything i come home and go over it and make sure everythings tight and right.
$7 an hour replacement workers anyone?
Old May 23, 2013 | 04:38 PM
hardheaded's Avatar
hardheaded
who ever put the plug in at the factory must have put the gorilla torque to it. threads came right out wrapped around the plug. he said it was hard to turn all the way out. the whole idea of doing your own oil changes is to keep the idiots at the dealer away from you stuff. don't have any faith in the dealers, had nothing but problems with them from scratching the wheels to not putting enough oil in and leaving things loose. had a buddy of mine had a rear tire put on and they didn't put the pulley side spacer back in, made it about a mile and tore up alot of stuff. anyway you would think from the factory it would 'nt have been that tight. he's probably going to want to weld it up and chrome it if he takes it off.
