Trailering a Street Glide
Old May 24, 2013 | 12:57 PM
PopsHD's Avatar
PopsHD
Default Trailering a Street Glide
For those of you who have trailered your Street Glide, where on the bike do you tie down to on the front? Keep in mind, I have fork mounted wind deflectors. I've heard the crash bar but I'm not sure about that. Thanks for any tips, advice, etc.
Old May 24, 2013 | 01:01 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Engine guard.
Old May 24, 2013 | 01:04 PM
Johnny103ci's Avatar
Johnny103ci
On the frame. right above the cross piece.
Old May 24, 2013 | 01:06 PM
Cowboy Rob's Avatar
Cowboy Rob
Big Kahuna HDF Member
This,also at the triple trees is good too. Just stay away from the handlebars.
Old May 24, 2013 | 01:55 PM
Ragtop's Avatar
Ragtop
The higher the better for the tiedowns, also get some softstraps!
I bike chock is well worth the money too, I use a Condor.
Old May 24, 2013 | 02:03 PM
cchenf50's Avatar
cchenf50
On the frame in front of the tank right before the neck.
Old May 24, 2013 | 02:58 PM
scooter_trash_1's Avatar
scooter_trash_1
Default Tie Down Points
I use choke straps (short straps that the tie downs fasten to) Go around the frame downtube and up over the crashbar, then down to tiedown..gets the tiedown away from paint and chrome parts..with high as possible tie off point..never had any problems with this arrangement, also use two in the rear off the footpegs backward angle also with the choke straps..Scooter
Old May 24, 2013 | 03:34 PM
BrianSF-GA's Avatar
BrianSF-GA
Ratchets & soft straps on all four corners and the engine guard mount on the front ....
Old May 24, 2013 | 03:58 PM
luc.who's Avatar
luc.who
I tie down on forks by the fender with a soft strap. One on each side. One strap thru the wheel on the front. I also have one strap on the rear wheel pulling the bike back. I agree with the wheel chock. I have the Harley chock its really a condor that I paid more money for. ... long story. ....
Old May 24, 2013 | 04:31 PM
soos's Avatar
soos
Having a chock is a big plus. After that tie off on the forks at the fender mount. Stay off the frame, triple tree,engine guard or anywhere else that will compress the front shocks. Tying off at the fender mount on the frame will allow your suspension to ride freely instead of compressing it and not allow slack to develop in your straps. On the passenger mounts just enough pressure to keep the bike from hopping and ALL strap pressure should be forward into your chock.
Attached Thumbnails Trailering a Street Glide-left-front-1.jpg   Trailering a Street Glide-right-front-2.jpg   Trailering a Street Glide-right-front-3.jpg   Trailering a Street Glide-right-passenger-4.jpg   Trailering a Street Glide-right-passenger-5.jpg
