Daymaker led light
Old May 24, 2013 | 08:11 PM
bbbobnca's Avatar
bbbobnca
Default Daymaker led light
I have been looking at the Daymaker light that HD has on the market. Other than the price it does looks like a good investment. I looked on their web site only to find that they will only fit Ultra's from 2009 and newer. I have a 2007 Ultra Classic. I talked to the parts guy today and it looks like the only diferrence in the two light setups is the attatchment ring. But one comes with the light. Typical HD wisdom they will not tell me why it will not fit on the 2007.
1) Does anyone know if this will fit or not. If not what is different.
2) If not what would pepole suggest for a good LED headlight.
Thanks
Old May 24, 2013 | 08:18 PM
mkguitar's Avatar
mkguitar
alot of guys use the trucklite.
there are many posts on this comparing the trucklite 6 and 7 versions to the HD.
incl. an exhaustive test by 2 riders, with great pics.
http://bogiesreviews.webs.com/Review...ng%20Lamps.pdf
not really an "investment" so you can do a cost/benefit analysis
I'm quite happy with the optics on my stock 09 system...at least until the led comes down.
mike
Old May 24, 2013 | 08:20 PM
HDV-GLIDE's Avatar
HDV-GLIDE
TL Phase 7 for under $200 with shipping at Eastern Performance's E-Bay site....
Old May 24, 2013 | 09:17 PM
bbbobnca's Avatar
bbbobnca
I read this but unless I missed it there was nothing about fitting on a 07 vrs 09 and newer. I know the JW Speaker/HD has a 8700 and an 8703. It looks like the 8703 has the same ring that the one at the HD store had in its box. Is there an article somewhere that tells me what fits on what bike or does it make a difference. What is the difference between the speaker 8700 and 8703. And before anyone answers the question I know its more that 3 ;-))
thanks
Old May 24, 2013 | 09:38 PM
Uncle Paul's Avatar
Uncle Paul
I installed the Truck Light on my 07 street glide, where it fit well and then transfered it to a 2012 Street Glide, and if fit just the same.
I installed a Frenched trim ring to hide the fact that it stuck out 1/3" due to the thicker lens.
Old May 24, 2013 | 09:53 PM
jberg's Avatar
jberg
These parts all match the size and shape of every out of the box 7" round headlight ever made so I see no issue with the year. I think the passing lamps may need a connection adapter for older apps but it's readily available.
Old May 24, 2013 | 10:14 PM
skratch's Avatar
skratch
check the hd website again...
pn 6700040A
Fits ’12-later DynaŽ FLD, ’94-later Touring and Trike models (except Road GlideŽ), and ’94-later FL SoftailŽ models equipped with the Headlamp Nacelle Kit. Kit includes mounting ring assembly. Gloss black lamp includes black bezel. Touring Black Headlamp Trim Ring P/N 46555-03A is available separately. ’06-’10 FLHTCUSE models require Harness P/N 71628-04 for installation.
Old May 24, 2013 | 10:51 PM
bbbobnca's Avatar
bbbobnca
The Harley web site is where I got my info. They are trying to sell a bunch of these so they put a app on their site that you put in your model and year and they will tell you what it fit. I tried both the year 07 and 08 and it said sorry. Starting with 09 and above it said it would fit. The new parts cat also states it will not fit the 07 as well as the label on the box itself. My thinking is the same as yours 7" should fit in a 7" slot. I do know for a fact they did change the ring in 09....I have the part numbers for both the 07 and 09 and they are different. ie thats the reason I posted my question.
Old May 24, 2013 | 11:09 PM
bbbobnca's Avatar
bbbobnca
Just looked again the 2007 and 2008 years only list 2 CVO models. It is intersting the 2006 lists
<li id="bikeModel_0" class="model">Heritage Softail Classic FLSTC<li id="bikeModel_1" class="model">Heritage Softail Classic EFI FLSTCI<li id="bikeModel_2" class="model">Fat Boy FLSTF<li id="bikeModel_3" class="model">Fat Boy EFI FLSTFI<li id="bikeModel_4" class="model">Custom Vehicle Operations Fat Boy FLSTFSE2<li id="bikeModel_5" class="model">Heritage Softail EFI FLSTI<li id="bikeModel_6" class="model">Road King FLHR<li id="bikeModel_7" class="model">Road King Classic EFI FLHRCI<li id="bikeModel_8" class="model">Road King EFI FLHRI<li id="bikeModel_9" class="model">Road King Custom FLHRS<li id="bikeModel_10" class="model">Road King Custom EFI FLHRSI<li id="bikeModel_11" class="model">Electra Glide Standard FLHT<li id="bikeModel_12" class="model">Electra Glide Classic EFI FLHTCI<li id="bikeModel_13" class="model">Ultra Classic Electra Glide EFI FLHTCUI<li id="bikeModel_14" class="model">CVO Ultra Classic Electra Glide FLHTCUSE<li id="bikeModel_15" class="model">Electra Glide Standard EFI FLHTI<li id="bikeModel_16" class="model">Street Glide FLHX<li id="bikeModel_17" class="model">Street Glide EFI FLHXISo not a lot of reason in it.....other than the old comment about crap in crap out. They may have not listed it right on the web site but that does not explain the parts Cat I'm looking at.
Thanks for the help
Old May 24, 2013 | 11:56 PM
vzts4q's Avatar
vzts4q
The new web site is wrong in so many ways it unbelievable! The previous site was much better and had a section where you could download a PDF of the accessory catalog. The ability to get the install instruction for accessories also seems to be gone. It previously showed as fitting my 08 and now does not. But never fear it will fit 94 and later Touring bikes with a 7" headlamp.
