It's fairly normal. A bike clutch is a wet clutch which means its immersed in oil to help the packs naturally separate when you pull the handle. Cold oil is sticky and will cause the clutch packs to slightly stick to each other and grab when you try to start the bike up. Putting it in neutral will help not only start easier but keep your bike running a little better without the extra stress on the battery and starter.
Once the bike is warmed up the oil isn't as sticky and the clutch packs separate and I promise you won't feel a thing.
From: South Carolina-First to secede and hopefully the next.
Originally Posted by jake.h
I think, respectfully, that your comment misses the point. I don't trust the dealer. - they probably charged me for a clutch adjustment that they never did (at 1000k) I want to be able to stride in and say, "Hey, adjust my damn clutch."
I'd find another dealer. But with an attitude like that, I don't think it'll help in the long run.
The response you are referring to, which reads: "It is just breaking loose the static tension in the oil in the clutch discs. You are putting unnecesary strain on your starter," doesn't answer the question as to whether a clutch adjustment is all that is needed.
Sure it does. Google "static tension".
And really....a clutch adjustment at 1000 miles? C'mon. Unless there's a PROBLEM your clutch shouldn't need adjustment for another 1000 miles or so. Get a manual and check it yourself. Takes all of about 15 minutes.
And start your bike in neutral. Starting in gear is an accident waiting to happen.
The clutch does not need adjustment. START with the bike in NEUTRAL...
Mine's been doing this forever on the times i start in 1st... The bike should be started in Neutral, pull the clutch, it releases the "Static Tension" on the discs...The dealer will tell you it probably is fine...
I agree with most that you should not start in gear. But just to satisfy your imagination, if you start with the bike "hot" in gear, like if you stalled at a light, does it still lunge forward? If not, you'll know it is static tension from cold primary oil.
