Loose compensator bolt
150 ft. lbs. is at the upper end of the recommended torque for that size/grade fastener when dry. With the lubricity of the loctite it becomes even more questionable. Then another 1/4 turn?
By the way, HD specifies 140 ft. lbs.
Your lucky if you didn't cause any immediate damage, but the latent effects may haunt you down the road if you did in fact yield the bolt or the crankshaft threads.
EDIT: I assumed when the OP said bolt, he meant bolt. If it's another configuration with a nut and not a bolt, then please by all means disregard my comments.
I will update after I run it and go for a good ride, god willing, and thanks for the welcome,
The pre -07 compensator nuts are designed to put enough clamping pressure on the assembly to keep it from coming loose. Manufacturing tolerances being what they are allow for proper torque to be applied but if tolerances are off a bit and the "stackup" dimension is too deep, the necessary clamping pressure will not be achieved.
Generally, when a torque to angle spec is given, that angle from a specific pre-set torque value is the one that has been shown to provide the proper clamp load for the assy in question. The method for obtaining that angle value is somewhat beyond the scope of this forum, but a google search for "torque to angle", "torque to yield", etc. should prove interesting for those so inclined to investigate further.
AFAIK, pre '03 (tapered roller main roller bearing) have a torque spec of 150-165 ft/lbs and the '03 and later motors use the to torque to value then to the specified angle. Whichever method is correct for your particular motor, it's a good idea to check and make sure that the compensator stackup is correct and the proper clamp load is being achieved. Trimming the compensator nut ~0.030 or using a shim under the nut are commonly done to solve any stackup issues. The OP may want to check out HD bulletin M-1170 ...
The photo below illustrates the point and how trimming the compensator nut will achieve the desired results.
I am strongly considering replacing one of them with a 2014 Indian; the MoCo is about to have some serious competition from a motorcycle truly made in the USA. Maybe the competition will motivate the MoCo to get off their collective dead a$$e$ and up their game but that is a topic for another post.
