Tour Pak Hinges
Old May 30, 2013 | 07:46 PM
Keithhu's Avatar
Keithhu
Originally Posted by journeyman
An extra set of hands is good to have.
Some tape covering the paint next to the hinge is cheap insurance.
Use care not to cut into the foam seal.
That, and a putty knife.
Old Jun 15, 2013 | 05:27 PM
Larry Jeffords's Avatar
Larry Jeffords
Default Easy
I did mine today. Nothing that hasn't been said already. New 3/16" bit, take your time, follow the instructions. Two hours tops from start to finish including a quick wipe down for fingerprints. Can be done by yourself but an assistant would be helpful. No one mentioned a small shop vac to remove the metal shavings but a necessary evil.
Far better looking that the originals. Why does HD cheap out on little things like this? Especially something so easily visible.
Old Jun 17, 2013 | 07:54 PM
Spider51's Avatar
Spider51
I did hinges and latches on my 2013 CVO Ultra. Bout an hour for the hinges but the latches were a different story. Took me about two hours but if I did it again it would only be about an hour. The rear lid catch is a real pain in the butt. But they sure look purty when it is done. The kit has a drill jig but it only gets you close for drilling the new holes. I had to enlarge the top holes to get it to fit flush. All worth it in the end.
Old Jun 17, 2013 | 08:14 PM
themensh's Avatar
themensh
Did it al by myself....by as has been said....an extra pair of hands to hold the lid for re-install may be nice. Can be done alone though.
Old Jun 17, 2013 | 09:26 PM
davessworks's Avatar
davessworks
Do not simply remove the rivets and install the screws. The screws need a slightly larger hole. Use the correct drill bit per the instructions. I've heard of owners cracking their lids by installing the screws into the smaller rivet holes.
Old Jun 17, 2013 | 10:04 PM
steelerdude1's Avatar
steelerdude1
So I gotta ask, Is this truly just a cosmetic thing, or is there another benefit? They look really nice!
Old Jun 18, 2013 | 04:49 AM
mike5511's Avatar
mike5511
Probably just cosmetic. But it looks so much better I would think the MOCO would make them original equipment because they make the old ones look so cheap and bad!
I made one little boo boo, slipped, but it was on the inside and nobody will ever see it unless they are replacing the hinges.
JOECAKRON
2014-2024 Touring Models
Dec 16, 2017 02:25 PM
t059736
Mar 18, 2011 10:07 PM
m50
May 19, 2010 03:27 PM
Kugie's HOG
Sep 18, 2009 11:41 AM
99igor
Oct 7, 2006 12:45 PM
