Why "true duals"
Old May 31, 2013 | 08:52 PM
  #41
oldhippie's Avatar
oldhippie
Originally Posted by HDV-GLIDE
I guess MGS Custom Bikes is lying to everyone about the hp/torque increases with their true duals.....Think Not......
True duals will provide better hp/Tq at high RPM, but at the cost of loss of HP/Tq at low rpm. Where do most people do their riding?
With True Duals there is no scavenging effect where the exiting exhaust of the previous cylinder firing pulls the exhaust from the current firing cylinder. This is why 2-into-1 are the best performers.
Bottom line, true duals are not a benefit for most of us, because we run lower rpm ranges as we cruise/tour. Now, if you're above 3.5K on the tach a lot, they may be a benefit.
Old May 31, 2013 | 08:56 PM
  #42
Hotrodz_n_Harleyz's Avatar
Hotrodz_n_Harleyz
Fact of the matter is, unless you just want to have every bit of performance you can get, ANY after market pipes with a high flow air cleaner are going to be better than the stock setup, and sound better to, assuming you want more sound. If you like the look and sound of true duals, then get em. if not, don't. literally that damn simple. People are gonna argue all day long, with the vast majority not havin a damn clue what the hell they're even talking about. Truth of it is, 90 percent of the time you ask a question like this, what you're gonna get is everybody tellin you what they have is the best. I have a 2000 road king with a bone stock motor with the exception of vance and hines slipons and a forcewinder intake with a K&N filter, and i've never once been pissed off about not having enough power.
Old May 31, 2013 | 09:02 PM
  #43
lumper's Avatar
lumper
You lose a little torque and hp when you go with Duals over a 2 into 1 UNLESS you get some stepped high performance true duals that are out there and compare them to a poor performing 2 into 1.
generally speaking a 2 into 1 will perform better than true duals.
I have always run true duals, I ran rinehardts I love the look and sound, but this time I am going with a 2 into 1 technically, it is actually two short head pipes that terminate in a small collector on one side of the bike.
I went this way because after riding 2 up with bags full and the bike loaded I needed more torque when traveling especially for passing but even riding big hills, or taking off on a hill fully loaded even with the 103 I need more.
I dont wan t start with cams and beyond, I want to get my gains in a good stage one so I need to count every extra bit I can get to be satisfied.
I will tell ya in 4 days when they arrive and I tune the bike and install everything.
Also I decided in time I am going to do a set of stretch bags I really like a lot and there arent any true dual pipes that are going to easily work with them so I went this route, personally I think they look better and they definitely perform better from everything I have seen and everyone using them I have talked to.
Lump
Old May 31, 2013 | 09:04 PM
  #44
Punjabi Rider's Avatar
Punjabi Rider
True dual is such a simple and whole lot cheaper design vs stock if that is the answer for a better performing motor Harley will go for any cheaper supplier instead of the complicated and too many pieces stock system.
Old May 31, 2013 | 09:08 PM
  #45
vegashd's Avatar
vegashd
WTF did you say????
  #46
Rootro's Avatar
Rootro
your pipes will get a lot hotter with true duals and it will be louder. That's the difference. Oh, and it will cost you about a $1000 more.
Old May 31, 2013 | 09:35 PM
  #47
FX4's Avatar
FX4
Originally Posted by vegashd
WTF did you say????
He said true duals are a simpler design and cheaper to manufacture. If they really worked Harley would adopt this system to reduce manufacturing costs. He is correct.
Old May 31, 2013 | 09:46 PM
  #48
Kadorja's Avatar
Kadorja
If you pay a grand for true duals over any other exhaust you got ripped off.
Old May 31, 2013 | 09:57 PM
  #49
vegashd's Avatar
vegashd
It's not correct, hd has used a couple of the biggest names in the exhaust business. They are after controlling emissions..... That's it!
Old May 31, 2013 | 10:11 PM
  #50
benford46's Avatar
benford46
Originally Posted by mrmud4x4
This is why I changed mine......
Same here
