Engine Temp
Old May 30, 2013 | 09:57 PM
rkoivisto's Avatar
rkoivisto
Default Engine Temp
Last weekend I was returning from a trip to Milwaukee and I thought I would try to compare engine temperature with the lower fairing vents open and closed.
Old May 30, 2013 | 09:59 PM
2black1s's Avatar
2black1s
And???
Old May 30, 2013 | 10:10 PM
ZUTEDUFF's Avatar
ZUTEDUFF
I hate when aliens abduct folks when they're trying to tell a story........
Old May 30, 2013 | 10:11 PM
rkoivisto's Avatar
rkoivisto
Default Fricken laptop
I hit enter and it posted.
The long and short of it is I used the power vision to watch engine temperature with the vents open and closed and saw no significant difference. I would like to know if others have done that and found the same result.
I would also like to know if anyone has compared ET with lowers installed and without lowers. I know I'm going to have to do this, but it would be nice to see others that verify what I find.
Old May 30, 2013 | 10:21 PM
pat1's Avatar
pat1
My RG runs cooler with the vented lowers on.
Old May 30, 2013 | 10:25 PM
mkguitar's Avatar
mkguitar
I compared lowers on/off
105ş ambient
loop: 1 mile at 30 MPH to fwy- 9 miles at 60 MPH...off, on to ramp...9 miles at 60 MPH, 1 mile at 30 mph.
first rode the bike to get to operating temperature.
removed fairing lowers
then did loop 1
put on the fairing lowers
then loop 2
measured at the oil dipstick, temps were 25ş lower with fairing lowers in place
mike
Old May 30, 2013 | 10:27 PM
Retrop's Avatar
Retrop
He must have fallen asleep.
Old May 30, 2013 | 10:29 PM
rkoivisto's Avatar
rkoivisto
Default That's what I was looking for
105ş ambient
then did loop 1
then loop 2
mike
Thanks, When I look at the lowers, it seems to me like they funnel air into the motor. But I've heard a lot of conflicting information on the subject. It looks like you went about it in a very systematic way.
Old May 30, 2013 | 10:32 PM
mkguitar's Avatar
mkguitar
part 2:
the increased air flow across the motor may result in more heat removed from the motor...but directed at the rider especially the right thigh- the "blow dryer effect"
that's ok, I'd rather my motor be happier, I wear thick jeans
using the fairing adjustable deflectors to direct air into the cockpit does help
mike
Old May 30, 2013 | 10:38 PM
rkoivisto's Avatar
rkoivisto
Default Lowers
part 2:
mike
True, but if my little experiment holds true, opening the vents has little affect on engine temp and definitely makes for more rider comfort.
