Down shift or brake?
Old Jun 7, 2013 | 06:55 AM
  #81
rapp76's Avatar
rapp76
I usually slow down using both front and rear brakes, front more. While I am slowing I have the clutch in and am downshifting to the appropriate gear for the speed but I keep the clutch in the whole time. I am coasting but if I have to get out of there in a hurry I am in the right gear to do it.
I have several motor patrolmen friends for local and state police and they all teach that you should stop with the clutch in, bike in 1st gear, left foot down, right foot up. I have not become comfortable with that yet, even though I have only tried it a few time.
I keep seeing about using extra gas from downshifting, I understand that the motor RPM's increase when you downshift but its not because of turning the throttle, so does that really use gas? I must be missing something here... Plus, are you really worried about pennies worth of gas while riding your $20k plus bike???
Old Jun 7, 2013 | 07:23 AM
  #82
BoonDock_Saint's Avatar
BoonDock_Saint
If I know I"m going to have to stop, I might downshift till I get to 4th, then grab the clutch. I downshift with the clutch disengaged as the speedo drops to keep it in the appropriate gear in the event i have to get out of the way and leave it in first at the stop. I agree, brake pads are cheaper and easier than clutch plates and somewhat easier on my tranny.
Old Jun 7, 2013 | 12:48 PM
  #83
Ozglide's Avatar
Ozglide
Default Front belt sprocket failure
I had the front belt drive sprocket splines strip a couple of years ago and for a while I wondered if it was due to downshifting, but if that was the case I would think that type of failure would be much more common. I don't feel that I downshift to excess or put more load on the bike then most riders who use a combination of engine and brakes to slow down so I have come to the conclusion that it was a defective part. I replaced the clutch assembly and for a while tried to avoid engine braking, but have since slipped back into the habit. I do try to match RPMs with a throttle blip to relieve the strain but if I have to slow down fast that goes out the window.
I have never come across anyone else who has had that same failure on a touring model...I have an 03 Road King...thus my conclusion that it was a fluke due to a faulty part. The main transmission shaft splines were undamaged, but the sprocket splines were completly gone.
hdoilcan
13
May 31, 2020 09:18 AM
63 Red Tail Hawk
Apr 27, 2017 01:35 PM
misput
Nov 4, 2013 07:02 PM
Alter
Sep 20, 2011 04:37 PM
ambrose
Mar 16, 2010 10:41 PM
