your shop gave you bad advice. A stage one TC motor will be very happy between 2,500 and 3,000 rpms. Nothing at all wrong with cruising a few hundred rpms below that on a good road with no wind.
Are you sure he wasn't telling you to shift up at 4 to 5 grand when accelerating hard?
I suspect your mechanic misunderstood the question, or you misunderstood that answer. No one cruises at 4-5000 RPM. For one thing, that's over 100 MPH in fifth gear, let alone sixth.
I suspect he was giving you a recommended shift point for fast acceleration. Which is about right for a bike with stock cams and heads. Anything above 5,000 RPM is just making more noise, not more power on a stock/Stage 1 motor.
