Cant enable EIMTS with power vision.
Old Jun 8, 2013 | 05:18 PM
cpd2442's Avatar
cpd2442
Default Cant enable EIMTS with power vision.
I get the flashing green light on the cruise indicator light when rolling the throttle forward. When i go into my pv and go to try to check the EIMTS box, it wont check, its like its disable.
Also, does anyone know what active intake and exhaust means and does when you check those boxes on the pv?
Old Jun 8, 2013 | 05:41 PM
skratch's Avatar
skratch
if you've got the flashing green light on the cruise, then i'm pretty sure that you've got eitms enabled. if you really want to check, then put your pv where you can see it, switch your gauges on the screen so you can monitor head temp, and let it idle until it reaches over 280*. if the rear cylinder doesn't shut down, then you've not got it enabled.
i know i've seen it before in winpv, but i just pulled up my map and eitms isn't even in there anywhere. but mine definitely works.
as far as active intake and exhaust goes, don't worry about them. those are for the hdi bikes. we don't use them here in the states.
Old Jun 8, 2013 | 06:20 PM
cpd2442's Avatar
cpd2442
My bike got up to 315 in traffic and it did not kick in. I made sure the green cruise light was flashing green.
Old Jun 9, 2013 | 02:48 AM
Watch Guy's Avatar
Watch Guy
Default If the cruise light is flashing green then it's not
going into EMITS. I can't tell you what's wrong but I know from experience, if it's flashing, it's not engaged.
Old Jun 9, 2013 | 05:58 AM
Delta's Avatar
Delta
Check marking the box does nothing. You have to open that line and then change the 0 to a 1. If it didn't 't activate st 315, then the temp is set wrong. Go to EITMS Trmp On and change the value. I use 284. I'm not at my computer so my terminology may be off.
Old Jun 9, 2013 | 06:10 AM
Drilln'Boss's Avatar
Drilln'Boss
Mine is set for 284 but doesn't kick in till 289.
dwl25
2014-2024 Touring Models
13
Aug 26, 2015 02:54 PM
Newharleylover
Exhaust System Topics
Jul 1, 2013 06:41 AM
EL ROADKING
Jun 23, 2010 09:05 PM
FLWanderer
Aug 28, 2006 11:55 AM
SubZer0
Apr 21, 2006 05:14 AM
