Front Brake Caliper Question
With my bike up in the air on a lift, if I spin the front wheel, should it spin freely, or is it normal for the brake calipers to restrict the wheel from spinning?
If I spin the front wheel, there is enough contact and friction for the wheel to make less than one full spin.
If this is not normal, steps required to fix?
I can hear the calipers on the rotor as I'm riding.
Thanks guys!
I'm assuming original pads? How many miles on the bike.
Try here, here and here for advise, also try flushing the fluid. It may be gunked up. If your a rookie brake bleeder speedbleeders can assit.
http://www.lyndallbrakes.com/service-tech/
http://www.motorcyclemetal.com/downl...rake%20Pad.pdf
http://speedbleeder.com/
