ignition help please
Old Jun 11, 2013 | 09:10 PM
Ultra Pearl's Avatar
Ultra Pearl
Default ignition help please
removed ignition to change bars, 08 ultra, when I went to put it back inI turned the bars to lock position to re install ignition but they wouldn't lock. now I cant get ignition lined up to get it to lock I tried moving the top and bottom seperately but have totally f**ked up........Please Help
I have watched the vids on here
Old Jun 11, 2013 | 09:20 PM
Android's Avatar
Android
Try looking here. I believe you can get it done with the help found here:
https://www.hdforums.com/forum/touri...on-switch.html
Old Jun 11, 2013 | 09:46 PM
Ultra Pearl
Thanks I got it back in but its sticky now and you have to move the bars hard to the left to get them to lock. To unlock them you have to pull on the a bit to get the switch to release..like something is nipping or jaming it a bit
Old Jun 11, 2013 | 09:50 PM
mainboom150's Avatar
mainboom150
if you cant get it watch this video and if you havent make this tool. i used 5/16 copper tubing. you shouldnt have to push or pull on anything i would pull the lock again make this tool and start over
Old Jun 11, 2013 | 09:58 PM
Android's Avatar
Android
AWESOME Video. It is on my to-do list now. That alignment tool is around 70bucks. Copper tube is way cheaper and works pretty cool. Thanks for that video.
Old Jun 11, 2013 | 10:06 PM
Wanna Ride's Avatar
Wanna Ride
That video explains it perfectly. An important detail is you MUST remember to depress the tab on the bottom of the switch **** housing when reinstalling everything. A lot of guys make this mistake and can't get it back together.
I work on fairing bikes quite a bit, so I went ahead and bought the alignment tool... found one online for $75.
Old Jun 11, 2013 | 10:10 PM
SBates08's Avatar
SBates08
I used a wide blade screwdriver with no problems. There's a couple different ways that you can pull the switch out. The way I was doing it to start with was definitely the hard way. Locking the forks and using the key is absolutely the easiest way to take it out and using a tool of some sort to turn the switch to keep it lined up.
05UltraBob's Avatar
05UltraBob
I bought an aluminum alignment tool for $25.00 + $4.00 Priority shipping. It works great!
http://www.marcparnes.com/HarleyIgnitionSwitchTool.htm
Old Jun 11, 2013 | 10:12 PM
T_Dogg80's Avatar
T_Dogg80
I got this one as well. Works great!
Just a note for anyone with an older Harley. I have a 2003 FLHTCI and you have to put the ignition to Access, not lock like in the video. Just a heads up.
Old Jun 11, 2013 | 10:43 PM
TexFF's Avatar
TexFF
Get a decent flashlight & look down there & make sure the slots are perfectly lined up. Just went thru this about 10 minutes ago. Also, use a screwdriver that's just slightly larger than a normal Stanley screwdriver. Worked for me!
Rzrback
Apr 28, 2016 06:04 PM
R BEE
2014-2024 Touring Models
Apr 28, 2015 08:55 PM
Dockt0r_Wh0
May 28, 2014 10:35 AM
Str33tgl1de
Mar 6, 2014 10:07 AM
W0ace
Dec 29, 2010 08:39 PM
