I talked to Howard today , he was getting ready for Sturgis , he said clockwise and counter clockwise are done looking from the bottom up not top down like I stated , my bad
Initially mounted the shocks on my own then removed the shocks after speaking with Howard, needed to assure they are mounted properly (in plane) between frame and swing arm mounting points. Howard spent at least 45 min. with me on the phone to assure I understood mounting, setting sag and setting damping. Only put 100 or so miles prior to leaving for Sturgis (1500 mi from NorCal). The first 1500 on them I was happy but not ecstatic. Saw Howard and the shock designer Jeff at the Rapid Harley and they insisted on getting my bike to them for a once over. They set the sag for two up but left it a little low so I probably won't have to reset for 1 up. That seems to work fine.
Bottom line is they are superb riding, 4000 miles over every type of terrain and not a single bottom. I am at 22 clicks although they were suggesting 16 to 18 with two up. I will play with that some.
Though my feet are still flat on the ground (32 in inseam) I am contemplating lowering blocks since my left leg touches the head pipe sometimes, yeoooow!
Can't say enough about the customer service from Howard and Jeff,
I can now say I am ecstatic, probably the single best purchase to date. Wifey Happy- Davey Happy!
Cheers
Cheers
can you expand on "mounted properly (in plane)"
not seeing how to mount them improperly with only a two bolt hole location.
Having mounted my Ohlins, some aftermarket shocks require spacers in the right places, so the shock is correctly aligned, top and bottom. If not, there is a risk of them being pulled out at top or bottom.
The shock mounting locations at the frame and swingarm must be on the same plane, if not you can ruin the shocks fairly quickly. You need to perform a basic measurementon your bike to know if shimming is required. The right side on my bike was in plane so no need for a shim (washers), the left side required a shim on the top mount due to the swingarm being out of plane towards the wheel.
All this info. comes from Howard and his website.
Cheers
Cheers
even after getting the shocks set up perfect,do they take the initial jolt out of the bike when going over a bridge that has a 2 inch or more diff. in road.
Howard installed my new shocks at Rapid Harley. Had me go out 3 times for ride quality checks and adjusted on two returns. Third time was perfect. I have over a thousand miles on them now and will re-adjust in a day or two. Does howard know his stuff...absolutely. Are the shocks better then OEM and worth the money. Yes, definitely.
Always hated the OEM shocks and this is a much improved ride and handling. Anyone that is happy with there OEM shocks and gets to ride a bike with Howards shocks installed, is in for a very pleasant surprise. Howard will take the time to make sure they are setup right and that you're completely happy with them. Cant think of anything else i bought in the last 40 years, where the seller was as concerned about there customers as he is.
