Cam recommendations please
Old Jun 14, 2013 | 11:34 AM
jdm65's Avatar
jdm65
"N" cams use the stock oem 2007 & up cam plate. The screamin eagle tensioner upgrade kit is the hybrid setup.
Old Jun 14, 2013 | 11:48 AM
Hogpro's Avatar
Hogpro
Former Sponsor
I have the 25284-11cam plate. It seems it is setup to take any cam that works on 99-06 models that utilize the bearings in teh cam plate as opposed to the newer style plate which has eliminated those bearings. So it seems a cam that fits 00-06 is what I need.
Old Jun 14, 2013 | 11:55 AM
bigirn's Avatar
bigirn
S&S Easystart cams have built in compresion release
Old Jun 14, 2013 | 11:56 AM
equandt's Avatar
equandt
Originally Posted by XARAN
I really liked the SE 204 in my 95" Fatboy. i plan on using them in my 103" RG as well this summer. Power is strong from idle up
Here is just one of many posted sheets
https://www.hdforums.com/forum/touri...-and-dyno.html
No doubt the SE204 is a great performer with a stock compression. With the OP's 10.25:1 compression the SE204 is going to build a lot of cylinder pressure and may have some detonation issues.
Another cam that may work well is the Andrews 37. It, like the Andrews 26 is "an oldie but a goodie". As I recall the 37 liked a little more compression.
The S&S 570 would still be my first choice. I ran a similar S&S510G in my '02 FLHRCI that had a 95" with head work but it was a 9.7:1 compression. That was a sweet running twinkie.
Old Jun 14, 2013 | 12:11 PM
Hogpro's Avatar
Hogpro
Former Sponsor
I run the 37 in my Dyna and the power band is not what I am looking for on my bagger. My concern with the 26"'s is that it says it is for stock compression. How will my higher 10.25:1 cr affect this cam?
Old Jun 14, 2013 | 01:01 PM
Tn.Heritage's Avatar
Tn.Heritage
You need to remember though that running 10.25 comp you will need a later closing cam to keep cylinder pressure down or you will be the King of Detonation. You don't want that. So with that kind of compression I'd think a TW6 or the SS570 would be a good fit.
Old Jun 14, 2013 | 02:49 PM
0ldhippie's Avatar
0ldhippie
Andrews 37 & 50 will work with stock heads/springs but may be not enough for your compression?? Wood 408-48 or Lunati 21740703 may work well if ya don't want to do any head work.
Old Jun 14, 2013 | 03:33 PM
Hogpro's Avatar
Hogpro
Former Sponsor
I have discovered that the springs in 05 heads can accommodate a higher lift cam than my other bike which is an 02. Regardless, someone elsewhere mentioned the 4 degree advance would really move things to the left torque wise. High compression is all new to me. All of other builds have been less than 10:1 compression.
I like the idea with the easy start cams from S&S but it seems their power band does not really kick in until 3000 rpms too. Anyone else have suggestions? Thanks.
Old Jun 14, 2013 | 03:39 PM
notrailers's Avatar
notrailers
Andrews 54.
Old Jun 14, 2013 | 05:36 PM
glide2005's Avatar
glide2005
I know you said you don't want a late tq cam. But the Andrews 54 love high compression. I have them in 2010 96" with just head work. Stock push rods and stock lifters, gutted head pipes and American custom slip-ons, and ACR's. I just had it dynode last week. 96 hp and 96lb tq.
