What else with clay bar?
Old Jun 14, 2013 | 11:21 AM
TwoBlue02's Avatar
TwoBlue02
Default What else with clay bar?
I am going to do the clay bar treatment soon. What else should I do while the finish is clean? Swirl remover etc or just put a good coat of wax back on and call it quits?
Old Jun 14, 2013 | 11:23 AM
jeffreydsilver's Avatar
jeffreydsilver
Old Jun 14, 2013 | 12:24 PM
Terrabella's Avatar
Terrabella
The process is as follows;
1. Clay bar
2. Paint cleaner
3. Polish
4. Finish off with wax
That is the proper way to do the job.
Old Jun 14, 2013 | 12:43 PM
2black1s's Avatar
2black1s
If you are satisfied with the paint appearance after the clay bar, then simply apply some wax. If you have any hairline scratches or swirls you want to remove, then you'll need a polish to do so before applying the wax. Remember, the clay bar is not going to remove any paint defects/blemishes, it will only remove contaminants from the paint surface. It takes a polish to remove paint defects/blemishes such as scratches and swirls.
Terrabella nailed the complete process... Although I'm not sure what step (2) is as the polishing step (3) will also clean.
Old Jun 14, 2013 | 12:48 PM
PistonPuller's Avatar
PistonPuller
Depends on how your paint is. If you have swirls, then a swirl remover would be good. A nice polish with an automotive approved DA will do wonders. Finish off with a good wax for protection. Here is a picture of my black fairing that had a few swirls before I hit it with a low speed car DA and swirl remover
Old Jun 14, 2013 | 08:40 PM
hdbob2006's Avatar
hdbob2006
So,how old is the bike and what is wrong that you have to use the clay bar?
Knowing why you need the clay bar in the first place will answer what to do after......
lhgdale
Dec 22, 2012 06:09 AM
firefightermike
Jun 4, 2012 07:57 PM
paulhog
Nov 11, 2011 05:42 PM
RDFXDF
Detailing
Sep 24, 2010 09:47 AM
HDF Tech
Detailing
Jun 27, 2005 02:31 PM
