New (to me) RK owner, few questions
So, I bought an '01 RK (CV carb model) with 18k on it. It had been rarely ridden for the last 2 years. Picked it up, cleaned it, changed all the fluids, put a new battery in and it started right up. Also checked primary chain tension and drive belt tension. Brake pads are good. Put some sea foam in the tank and hit the road. It ran okay, but would buck a little bit at very small throttle openings. Okay, pilot's dirty, no big deal. I continued to ride as it steadily got better, to the point it rarely does it now. I may still pull the pilot though, as it seems like it takes forever to warm up. 30 seconds of idle with full choke, then about a minute or two or full choke riding and then it's pretty much good to go. I was going to ask if this is normal, but the service manual pretty much confirms this. Are these bikes lean from the factory? (Bike is stock). I am toying with the idea of going up a size on the pilot. Yes/no?
I also noticed that the shifter seems like it wiggles quite a bit before it moves the shaft. Normal? I have tried both aftermarket and stock shifters, they both do it. Heel shift has been removed and HD factory shaft cover installed.
Only other issue so far is that the check engine light came on a few times yesterday for about 3 seconds each time. I think every time I was in 4th gear. Checked service manual, it says to see the dealer.
Any ideas on the issues I mentioned, and is the anything else I should be checking? (I know about the cam chain follower issue, that's getting dealt with this year when the riding season ends.)
