Primary noise?
Old Jun 16, 2013 | 02:25 PM
Ndoggct's Avatar
Ndoggct
Default Primary noise?
Hello I've had a noise coming from my primary ever since I purchased bike..not sure if they all do this or not..defiantly sounds like a chain noise..oly notice when stopped at a light..actually totally goes away if my foot has any pressure on the shifter...is this normal?? 07 roadking with @18k..thanks
Old Jun 16, 2013 | 02:46 PM
06Cummins's Avatar
06Cummins
That doesn't sound like a primary problem sounds more like a tranny problem. Might wanna try to adjust your linkage.
Old Jun 16, 2013 | 05:32 PM
sargek's Avatar
sargek
Is the noise your linkage rattling? The shift shaft pivot in the primary (where your foot shift lever is bolted to) rattles because some idiot engineer thought a bushing would be good enough at this pivot point. The bushing wears out and the shaft rattles in the bore. Putting light pressure on the shifter stops the shaft from rattling and stops the noise. Is there a lot of slop in the shaft your foot shifters are bolted to?
Old Jun 16, 2013 | 07:20 PM
dh2683's Avatar
dh2683
Mine rattled right before it broke off. Check the pivot point on the linkage.
Kerr8005
Apr 22, 2016 09:34 AM
rhproductions
EVO
Nov 25, 2014 11:04 AM
Astro
Nov 19, 2010 12:45 PM
StreetGlider56
Nov 19, 2009 10:04 PM
zzmellio
Nov 5, 2009 03:50 PM
