Battery Question
Old Jun 20, 2013 | 07:05 AM
42gunner's Avatar
42gunner
Originally Posted by btsom
One of the guys either on this site or on another I frequent made a visit to the factory and watched the same innards going into all of the batteries regardless of the label ultimately stuck on them. Never had any reason to doubt his story, though you are free to do so.
So people just think its better because it has a "famous" label on it.
Old Jun 20, 2013 | 08:23 AM
Rick06's Avatar
Rick06
Originally Posted by Geoff
This Deka battery is made by the same company that makes H-D batteries. Anybody ever try one?
http://www.ebay.com/itm/DEKA-AGM-BAT...06e468&vxp=mtr
Put this DEKA in my 08 RK 2 yrs ago. No issues, starts the 103 every time I hit the button.
Old Jun 20, 2013 | 08:34 AM
vegashd's Avatar
vegashd
im sure he maybe visited the site but they are not going to be running the same batteries different brands at the same time. the runs are so large that it does not happen that way.
The specs are different... and a Harley battery will test higher CCA almost every time then all other "SAME" batteries.
HD has many parts made by companies who make their own products. but 9 times out of 10 its a proprietary part to their specs..... research their oil filters... not your everyday 5 micron filter. Before HD came out with one there was not a tested 5 micron oil filter in existence.
Old Jun 20, 2013 | 08:39 AM
grbrown's Avatar
grbrown
Geoff, it is likely that to find any date sticker on your battery you will have to remove it from the bike. While out you can take it to a local auto store and get it tested. If it tests OK, then stop worrying! Life is too short and there are a lot of other things that can go wrong out there. If you can't sleep at night, then get a new AGM battery and put the topic to bed.
Old Jun 20, 2013 | 08:55 AM
cass's Avatar
cass
ok, here is a simple suggestion.....take the bike off the tender while its at home and see if you have any problems. if not cool, if you do, go buy a new one. just a thought.
Old Jun 20, 2013 | 09:06 AM
tibadoe's Avatar
tibadoe
Best way to tell is to put a load test on the battery. Easy to do and only takes a few minutes. If you don't have the tester take the battery to a parts house and have them test it. If you do decide to pick up a battery, I would get the Deka or other branded names they sell under and save some coin. It's not the same battery - it has a different color case! But it's made to the same or better specs.
Old Jun 20, 2013 | 10:21 AM
Geoff's Avatar
Geoff
I plan to replace my battery to be safe. Just have to decide if I want a Deka ETX30L or HD 66010-97C.
The ETX30L is rated at 400 CCA. The HD site does not provide CCA info., but I think it's 365 CCA.
Besides price, the only difference I can find between the two batteries is the cable attachment. The post on the EXT30L is set back just a bit from being flush with the front face of the battery. For this reason the battery comes with a small (.080-.090") spacer for front cable connections.
Oh yeah, according to the HD web site, the 66010-97C has a "Distinguished H-DŽ Bar & Shield is molded into case for quick, confident recognition". Nice, huh?
Like dino and synthetic oil, if you Google this topic, you'll find an endless debate on HD and Deka batteries. This most interesting comment was from a guy who worked at East Penn Manufacturing, maker of HD and Deka branded batteries.
"I used to work there and I know that when they change the line over from Harley to DeKa, the only change is the case, everything inside the battery stays the same. The cover which has the terminals already molded in is added later on a different line."
More: http://harleytechtalk.org/htt/index.php?topic=22371.0
Old Jun 20, 2013 | 10:35 AM
grbrown's Avatar
grbrown
Talking
Best not to do that! The more time you spend looking, the more you will lose! That 400CCA sounds fine to me.....
Fishrrman
Nov 21, 2014 11:32 AM
pretz
Nov 3, 2014 09:07 PM
rooti
Jul 5, 2013 03:52 PM
mtinner
Jun 17, 2010 06:22 PM
Domestic Violence
Jan 30, 2007 06:43 PM
