04 RK questions
Old Jun 19, 2013 | 10:03 PM
ffron69's Avatar
ffron69
Default 04 RK questions
I am looking at an 04 FI RK and I have a couple questions.
1. the heel part of the heel toe shifter is missing, anyone know where I can get one inexpensively?
2. bike has no mods aside from slip on Screaming Eagle mufflers, any thing to be concerned about at 24,000 miles?
3. the front tire (and probably back) spokes are kinda cruddy, are they fairly easy to clean up or is it a lost cause
4. do the leather looking RK bags keep the water out?
Thanks for the help!
Old Jun 19, 2013 | 10:30 PM
NAILIT RK's Avatar
NAILIT RK
First I would ask about the camchain tensioners and if they had been upgraded from the spring loaded style to Harleys upgrade kit with Hydraulic tensioners. I just did a build on my 01 RK with 22,000 miles and changed out the tensioners etc. they were in pretty bad shape.
Old Jun 19, 2013 | 11:07 PM
JerryS63's Avatar
JerryS63
My leather RKC bags stay dry inside so far. I am sure if you ride in bad enough they may get some water
Old Jun 19, 2013 | 11:57 PM
bagman1's Avatar
bagman1
Too bad youre not here in Cali. Im selling a 04 RK custom that I switched to hard bags and added chrome front end with Classic passing lights, 9 spoke black/polished rims and vivid black paint. Bone stock except for V&H Ture Duals, also has the rear shifter and the bags are waterproof.
Old Jun 20, 2013 | 05:10 AM
ffron69's Avatar
ffron69
Thanks I did ask he doesn't know only had it a year and 1000 miles just too heavy for him...
Old Jun 20, 2013 | 05:11 AM
ffron69's Avatar
ffron69
Thanks Jerry that is about what I was guessing
Old Jun 20, 2013 | 05:12 AM
ffron69's Avatar
ffron69
Sounds nice, I am actually looking at trading him my 07 FXDL for the RK...
Old Jun 20, 2013 | 06:24 AM
Road Ranger's Avatar
Road Ranger
1. the heel part of the heel toe shifter is missing, anyone know where I can get one inexpensively? Should be able to order directy from HD
2. bike has no mods aside from slip on Screaming Eagle mufflers, any thing to be concerned about at 24,000 miles? As others have said...Check the cam chain tensioners and either go with the new HD set up or install gear driven cams and forget about it...You can do this as long as the crank runout is within tolerance.
3. the front tire (and probably back) spokes are kinda cruddy, are they fairly easy to clean up or is it a lost cause. They are a pain in the *** to clean keep clean but once they're clean they sure look good. I use the westley's bleche white and spoke brush to clean mine...It does a really good job.
4. do the leather looking RK bags keep the water out? Yes, I've never had issues with water getting into mine and I've ridden through some significant rain showers when touring.
Old Jun 20, 2013 | 06:31 AM
ffron69's Avatar
ffron69
Thanks - any idea what it costs to replace/fix the tensioners?
Old Jun 20, 2013 | 07:56 AM
Jeff Vorhies's Avatar
Jeff Vorhies
I just had S&S 509 gear drive cams put in by an INDY, cost me right at $1100
