PCV Map needed
Old Jun 21, 2013 | 06:27 AM
Notgrownup's Avatar
Notgrownup
Originally Posted by slimvela
Surprising, they have yet to respond to multiple emails/voice mails for this very service. Even offered to pay for a map.
I call bull.
They are extremely busy, it took me 5 days to get a response... Patience...
Old Jun 21, 2013 | 08:22 AM
ke5rbd's Avatar
ke5rbd
Originally Posted by aviscomi
I'm looking at your sig and you're running the stock pipes along with a catless headpipe. If the map you supplied to me is the current map you're running, I doubt it will work.
I am also running a power vision and se pipes now. That map got 44 mpg on road and ran cool and lots better than stock. It ran close to the one fm sent me, actual power was same and mileage was 5 mpg better. It really only matters on the exhaust if it is a 2 in 1 in 2 which power duals are or if 2 in 1 or true duals makes difference. Throw cams in the mix and it gets critical for sure.
Old Jun 21, 2013 | 11:28 AM
ke5rbd's Avatar
ke5rbd
I converted the PV map I am running now to PCV. The fuel isn't that much different. The timing map is what makes this one tick. I haven't run this one on a touring with PCV, but it works great on several with the PV. No reason it won't work of the PCV. It only takes a few minutes to try it. If it works on the PCV as it does the PV you will like it. I have used this timing map on probably 15 different bikes from stock to TW888, and it works on all. No ping even on 10.5 motors as the area they ping in has the timing reduced 4 to 6 degrees. Anyone else that may want to try it jump on it. It ain't patented.
File Type: zip
Touring 103 stage 1 from PV.zip (916 Bytes, 18 views)
Old Jun 21, 2013 | 11:33 AM
slimvela's Avatar
slimvela
3 months and counting...gave up 2 months ago. We all have different experiences.
Old Jun 21, 2013 | 11:40 AM
ke5rbd's Avatar
ke5rbd
If you bought it from them and they haven't replied contact them something is wrong. If you didn't buy from them, may not hear from them.
Old Jun 21, 2013 | 12:20 PM
Tanker2's Avatar
Tanker2
I have a 2012 ultra 103" with PCV,power duals, 4" Rineharts, SS air cleaner. I have several different downloads. I bet the one I'm running now would be real close. Also stops the deceleration pop.Send me your email in a PM and I send it to you. It's from Fuel Moto
Old Jun 21, 2013 | 08:24 PM
Notgrownup's Avatar
Notgrownup
I also would say that there must be something wrong...I have never waited more than a week for a response... Not trying to make excuses for them. Sorry you have had a hard time with them.
BezerkoBob
Fuel Moto / Jackpot Mufflers
Jan 10, 2017 06:50 AM
tigger01291958
Oct 30, 2015 04:01 PM
danzio
Sep 1, 2012 04:55 AM
UltraDune
May 8, 2012 04:06 PM
dohadex
Feb 21, 2011 06:46 AM
