Loose fairing insert for windshield screw
Old Jun 21, 2013 | 01:30 PM
trackadaptor's Avatar
trackadaptor
I just replaced another one as suggested:
1.) Inserted the "Self Taping" Slotted End First
2.) I used the Torx screw and I went in smooth !
Thanks guys !
Originally Posted by 2black1s
Totally agree.
And I'll go a step further and say that if you do tap the hole first, your repair won't be as robust because the new threaded insert will not fit as tightly.
Old Jun 21, 2013 | 02:24 PM
dugan's Avatar
dugan
Went to Lowes and got brass inserts for half the HD price. Same size, but bigger threads which should hold better. Like others have said, slotted end goes in first, then a screw it in with a T-27 torx.
Old Jun 21, 2013 | 05:34 PM
Fathead2003's Avatar
Fathead2003
I picked up two just to have on hand @ $1.75 ea.. The dealer said to use a flat head screwdriver in the slot to install.
Old Jun 21, 2013 | 06:00 PM
2black1s's Avatar
2black1s
The Dealer is wrong!
And here's a couple of points from an engineering perspective as evidence...
1) Why would you want the slotted end out thereby resulting in incomplete threads at the screw mating surface?
2) Where does the displaced material from cutting the threads go when you install the insert solid end first? That's what the slots are for so they need to go in first.
Old Jun 21, 2013 | 06:11 PM
Deuuuce's Avatar
Deuuuce
Subscribed because the OP bugs the **** out of me with his random vacation pics but also offers useful information.
Yes, we know each other.
Old Jun 21, 2013 | 06:25 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
That dealer is wrong. If you do it that way, you'll be screwed. So to speak. And they have them at Lowes for $. 40-.50 each.
Old Jun 21, 2013 | 11:16 PM
trackadaptor
Wink
Now I can bug the Sheet here too
Old Jun 21, 2013 | 11:21 PM
trackadaptor
The Slotted End is "Self Threading" don't use a screw driver..... use the #27 torx screw as talked about
I work for a machine shop my head machinist agrees...
Old Jul 17, 2013 | 12:59 PM
03electraglide's Avatar
03electraglide
What is the size from lowes or internal thread needed for factory bolt
Old Jul 17, 2013 | 01:11 PM
Smokey Stover's Avatar
Smokey Stover
I over tightened one once and it pulled out, I just epoxied it back in, its held for a year but I will definatley pick up a few the next time im in Lowes. thx all
