Another Compensator Thread?
Old Jun 22, 2013 | 10:06 PM
WB's Avatar
WB
If it is the comp most likely will notice a rattle in primary when you engage the clutch in first gear. Seems to be worse when cold for mine. . You will also notice a rattle when you kill the the motor and clutch it. When you hear a comp on startup you will definitely know it is not a normal start. The start "bang" is loud as hell.. At least this is how my scoot acted before replacing.
Old Jun 22, 2013 | 10:41 PM
cchenf50's Avatar
cchenf50
I'll start with the easy stuff first tomorrow. Even though the battery was new, it was dead the other day for some odd reason. I'll set it on the charger for a while and when I put it back in I'll triple check all of the connections.
Does it hurt to ride it like this? Weather is too nice to park it to work on it. I'll see if I can upload a video tomorrow of a cold start and a warm start as well.
Old Jun 23, 2013 | 07:57 AM
btsom's Avatar
btsom
Sounds like several problems hitting all at once. "Dragging starter" doesn't help me much, is that trouble getting past the first compression stroke or is it a terrible grinding sound? If the starter stalls trying to push through the first stroke, that may be related to the battery dying. Poor connections at either end of the cables to the battery or something wrong in the charging system. Some piece of gear not turning off with the master switch also might be draining the battery.
If you mean the loud grinding noise, that is most likely the starter drive clutch. The compensator running out of travel and slamming against the stop seems to beat the starter clutch to death. The compensator absorbs a certain amount of travel and then becomes solid against the stop. It can't cause a "dragging" or hard to turn over situation, that has to be electrical connections, weak battery (no matter how new) or starter in the process of an early death.
Trouble shooting gets complicated in a hurry with multiple malfunctions. The new compensator will fix the bang when engaging the starter but if the starter stalls on the first compression stroke, that is a separate though related problem. What king of battery did you buy?
Old Jun 23, 2013 | 02:16 PM
cchenf50's Avatar
cchenf50
Hot start video
Old Jun 23, 2013 | 04:44 PM
rare100thHD's Avatar
rare100thHD
Had that exact Problem with mine, replaced the Starter Clutch with a All Ball Brand Starter Clutch, it is heaver duty than the HD ones, and it has larger internal parts which completely stopped the Hot Start Grinding Sound on mine. Trust me this will solve your problem.
Old Jun 23, 2013 | 04:48 PM
cchenf50's Avatar
cchenf50
Perfect, I ordered the All ***** last night. Any pointers on how to change it? I have a service manual, but it's not real in depth.
Old Jun 23, 2013 | 04:51 PM
Stiggy's Avatar
Stiggy
Until you get it worked out, in the meantime when you do a hot start ( like while getting gas,) try hitting the start button as soon as you turn on the ignition....Don't wait for the red light to go off. For some reason ( on some bikes,) it'll start on the first rotation and save your ring gear for awhile longer.
Old Jun 23, 2013 | 04:53 PM
brownfoxx1's Avatar
brownfoxx1
info: jimsusa has a compensator lock.( a ring with ears on it so you can bend it over the flats on the nut).$160.00
Old Jun 23, 2013 | 05:25 PM
Assegai's Avatar
Assegai
Good gen in the attached link re: starter clutch replacement. My compliments to SCUBAMIKE.
https://www.hdforums.com/forum/touring-models/699634-starter-clutch-replacement-on-09-sg.html
peteknok06
Oct 2, 2017 01:57 PM
Aylor70
Nov 12, 2012 09:40 PM
BiggDogg
Mar 21, 2012 08:23 AM
Hardly Dangerous
Mar 9, 2010 07:21 PM
CalSport10
Feb 18, 2009 04:21 PM
