Here's a video of what my bike is doing when I start it after it is hot. Compensator? Starter clutch (new all ***** is in the mail)? Whatever it is is aggravating.
Actually yours doesn't sound that bad yet.
Mine sounded like loose bolts in a can before I changed out last week.
Yikes. My clutch should be in this week and I'll swap it out. Didn't have enough cash set aside for the clutch and the comp so I went with the cheapest one and I'll buy the comp in a few weeks. What all did you change?
sounds like starter is getting hung up during hot start. If you are installing a new starter, make certain you check your electrical connections and bolt the new started down tight. Had similar problems with an 07 RG that was due to loose starter bolts.
