static in cb
Old Jun 24, 2013 | 04:45 PM
1st 96 ultra's Avatar
1st 96 ultra
Default static in cb
I have been using my CB more on group rides and have a lot of static on my CB , I can turn the squelch up and get rid of it but afraid I am going to lose reception , I have a HID headlight and that seems to be the problem as I can turn it off and get rid of the static , looking for ideas to fix it other than changing my headlight
Old Jun 24, 2013 | 05:06 PM
Lowcountry Joe's Avatar
Lowcountry Joe
If any part of the HID circuit is emitting wideband RF garbage, then you may be screwed. If it's simply a condition of wires coupling, then it's possible that some ferrite toroids of the appropriate material may work to suppress the noise.
A good material to suppress 0-50mhz rf is the ferrite torroids made from K material. They can be found at Amidon Associates following this link:
http://www.amidoncorp.com/k-material-ferrite-toroids/
Ferrite suppression can work to suppress rf radiation of various wires and leads. Simply wind the suspect wire several turns through the ferrite doughnut and the ferrite will "choke" the rf in the design frequency range and keep it from radiating from the wire and into your very non-selective CB receiver. I would use these toroids on any leads going into and out of the HID module for sure.
There is no guarantee that this will work, it just depends upon the source and frequency of your interference. A quick call to Amidon may help. They are very friendly and will work with you on small quantity orders.
Old Jun 24, 2013 | 06:15 PM
bobgv's Avatar
bobgv
Will this work on radio reception as well?
Old Jun 25, 2013 | 10:45 AM
Lowcountry Joe
It can work if the problem resides in coupling between wires or feedlines or if a particular wire is acting as an antenna.
A lot of guys are running audio amps in their bikes and are experiencing interference from those amps. As I said in my original post, it depends on the type and source of the interference as to how you attack it.
You can take the shotgun approach and use ferrite chokes on all leads going into the amp and out of the amp. That should go a long way toward suppressing some of the noise. You will need a different material in the ferite because the FM broadcast band runs from 87 MHz to 108 MHz while CB operates on 26 MHz to a little over 27 MHz.
I would suggest the 43 material from Amidon if I were trying to suppress noise in the FM broadcast band.
http://www.amidoncorp.com/43-material-ferrite-toroids/
Pommerntat
Jul 6, 2014 02:17 PM
lawman1841
Audio Systems
Mar 30, 2013 06:08 AM
sdoomaha
Audio Systems
Apr 29, 2012 06:33 AM
redbaron72
Oct 19, 2008 11:54 AM
ROLLNTIGER
Feb 4, 2007 04:57 PM
