Kat Eye Led Tail
Old Jun 27, 2013 | 10:01 AM
NYSTREETGLIDE's Avatar
NYSTREETGLIDE
2nd Gear
Default Kat Eye Led Tail
I purchased and exteded fender for my flhx a bout a year ago and am finally getting around to installing it. The fender came with a pair of Kat-Eye led tail lights frenched into it. The problem is the wiring. These lights have 3-wires (red-stop, blue-turn, and black-ground). Im wiring them to connection under the seat which is 5 wires. Ive been fiddling with different combinations but haven't had any luck. Am I missing anything? Any advice is appreciated.
0[/IMG]
Old Jun 27, 2013 | 10:49 AM
bzb123's Avatar
bzb123
If there is only 3 wires, one will be left turn, one will be right turn, one will be running lights. You will have to ground the light at the mounting points.
You will then have to get a 5 to 4 trailer wiring adapter. Harley uses a separate wire for brake lights (like import vehicles use).
If I remember correctly, purple is left turn, brown is right turn, blue/white is running lights, red/yellow is brake, and black is ground.
Hope this helps.
Old Jun 27, 2013 | 11:19 AM
NYSTREETGLIDE
2nd Gear
Thanks for the help. Ill give this a try tonight.
Old Jun 27, 2013 | 11:50 AM
DuraGlide's Avatar
DuraGlide
Don't know if your bike has security but if it does it won't be happy with the LED lights. Will need a load equalized to make it work. Badlander makes one to use 2 lights for run/turn/brake.
dyna bob 583
Electrical/Lighting/Alarm
Jun 15, 2016 12:25 AM
Spartanden
Jun 21, 2014 07:36 AM
tader
Nov 3, 2013 08:40 PM
Orange Crush 2011
Mar 20, 2012 08:46 AM
gregorysfd
Nov 30, 2007 04:33 PM
