Strange think happened today
Old Jun 30, 2013 | 09:20 PM
2-Piece's Avatar
2-Piece
Did you tighten the battery cables after you installed your accessories? Check the simple stuff first...
Old Jun 30, 2013 | 09:35 PM
SubZer0's Avatar
SubZer0
Never took them off. Pulled max fuse to kill any power to the bike. But yes I did check everything as I was putting it bak together.
Old Jun 30, 2013 | 09:46 PM
2black1s's Avatar
2black1s
Originally Posted by SubZer0
**** it took me an hour just to remember how to check the codes. don't stress me.
New bike only about 2500 miles.
I thought the codes were in the manual, guess not.
The codes are in the manual. The Electrical Diagnostic Manual. I'm amazed at the number of people who will tell you that you need a Service Manual, but fail to mention the Electrical Manual. You need them both! And then, the Parts Manual is the icing on the cake.
For those of you in the market for a Service Manual, you really need to consider all three.
Old Jun 30, 2013 | 10:18 PM
Timpechos's Avatar
Timpechos
This happend to me once on my 08 e glide. It hasn't done it again in 16k miles, go figure
Hell I damn near forgot about it
Old Jun 30, 2013 | 10:37 PM
SubZer0's Avatar
SubZer0
It's done it to me twice in as many days.
I'll stop by the dealer on my way home from work on Tuesday and see what they have to say about it. I've never heard of a speed sensor not letting the bike ideal but who knows with the new all computer controlled bikes anymore.
Pulled the ECM out just for ***** a giggles to take a look at the pins, all looked good. But that thing was hotter then hell, that can't be good for electronics.
Old Jul 1, 2013 | 04:07 AM
30glock's Avatar
30glock
I wonder if the power and ground lines for the amp I installed have anything to do with it?
I would disconnect the amp and see if it goes back to normal, sounds like your pulling voltage. Before you take it to the dealer disconnect that entire set up, just in case they decide to blame it on your Mod..
Old Jul 3, 2013 | 07:03 PM
SubZer0's Avatar
SubZer0
Update: Well the same thing happened again day before yesterday on the way home from work only this time it set a code for the vehicle speed sensor. I took it to the dealer yesterday to have it looked at. Stop by today to see if they found anything and they tell me it's all done, found a flake of metal on the speed sensor, cleaned it off and took it for a ride. I asked if they changed the trans fluid to make sure they got it all out, he says no changing the fluid isn't covered under warranty, I told them I don't care change it anyway, I'd be more than happy to pay for it. He said no problem they'll get right on it. So I decided to head home and get my lid and catch a ride back to pick up the bike. About 100 yards out of the parking lot they call me and said the found much bigger problems after pulling the trans drain plug, covered in metal. So much for picking up the bike. They'll give me a call after the trans tear down and let me know what they fine.
I had another thread on here about rattling from the trans, guess we figured that one out too.
Funny only 2600 miles on the bike and something lets go in the transmission. NOT GOOD. O well at least it will all be covered under warranty and Ill get that fresh trans oil change I was asking for too. :-)
Old Jul 3, 2013 | 08:25 PM
flhxmc's Avatar
flhxmc
I read your last post about the noise. Kinda funny how you get flamed for asking a question then find out you have a legit problem. Good luck, hope you get everything resolved!
Mike
Old Jul 3, 2013 | 09:19 PM
dickey's Avatar
dickey
Doo dee doo doo doo dee doo doo doo dee doo doo doo dee doo doo
Submitted for your perusal; 1 Harley rider who goes by the name of SubZero. While motoring down the highway, he experienced what we like to call a moment of strange occurance; one where his bike registered no speed even though he was clearly booking. There is no reason for this, other than he was transported suddenly to a place & dimension where laws of physics have no meaning, a black hole of indifference, where time & reason cease to exist. unfortunately for SubZero, he has entered into a world where all things wrong can be found with a simple read of the numeric code in his speedo, but which can totally flummox him into a world where reality is just a whisper of thought. He has crossed into a world of both shadow & substance; He has just crossed into...The TroubleCode Zone!
Old Jul 4, 2013 | 08:51 AM
btsom's Avatar
btsom
My experience with computer codes is that most often they don't identify the actual problem or component but identify a problem area or system. In this case, those with experience identified the VSS from the symptoms before the code set, and even the code said nothing about a transmission turning to metal filings. The codes are just another tool in the trouble shooting sequence. The OP obviously made a better decision than the shop did and uncovered the actual problem.
