Wards cooling fan
Old Jul 1, 2013 | 04:59 AM
Campy Roadie's Avatar
Campy Roadie
What White Ice said. Plus, if you use the B connector they can cool the bike after you turn it off. If you're worried about it running too long when you park the bike, you can always flip the switch on the fan unit itself to turn it off.
Old Jul 1, 2013 | 07:35 AM
Am4wag's Avatar
Am4wag
How about battery draw when engine is off/after shutting down/then starting again a few minutes later (like out running errands,stopping for fuel,etc.).?
Old Jul 1, 2013 | 07:39 AM
lionsm13's Avatar
lionsm13
Good point.
What do does of you that run them notice that your temps are staying at?
Old Jul 1, 2013 | 07:54 AM
Hammy's Avatar
Hammy
Head temp and oil temp are 2 seperate measurments (don't confuse them).
I have the wards fans, they work, I have the temp switch it turns on at 185degrees cylinder head temp and shuts off at the same temp. The fans run for maybe 1 minute after shut down to bring the bike to 185 degrees head temp, then with heat soak the heads will get back over 185 and the fan comes on and shuts off, usually a 2 cycle for me here in MA. No issues with battery drain.
Old Jul 1, 2013 | 08:25 AM
lionsm13's Avatar
lionsm13
Yeah, I get that, and I'm not confused but since you brought it up, what is your oil temp at when your heads are 185 out of curiousity?
Old Jul 1, 2013 | 09:15 AM
CndUltra95's Avatar
CndUltra95
I do not use the Wards cooling fan, but have the HD Parade fan.
It has the thermo switch mounted to the inboard side of the backing plate of the
Air-cleaner. It worked great for the first couple years .The fan only would come on if I was sitting in +70 degree weather and ideling for more than 5 minutes (traffic jam or Border lines) the thermo switch does work.
I broke a wire and decided to put a switch in and have no problems forgetting if it is on or not.
Two different fan types and two different opinions.
Rob
Old Jul 1, 2013 | 10:17 AM
Lowcountry Joe's Avatar
Lowcountry Joe
If some of you think that flipping the switch on and off is the way to go, then have at it. You will likely heat damage your fans over time, put excessive wear on the mechanical switch, and disallow the fans to operate at their maximum potential.
The Thermal Switch is $20 shipped. A moron can install it. (like me!)
Old Jul 1, 2013 | 10:38 AM
Hammy's Avatar
Hammy
it depends, I have a 10 row oil cooler also, usually my oil temp never goes above 228 degrees, the fans have turned on at 200 degree oil temp, but have had them cycle on and off at oil temps 220-228..
Old Jul 1, 2013 | 11:40 AM
Lowcountry Joe
Perfectly normal. Head temps and oil temps are different at any given time you want to measure them. The fans cool the heads. Sounds like the thermal switch is doing it's job well. It's very normal for the fans to run while riding down the road when ever your head temp reaches the turn-on temp which is around 185 degrees plus/minus a few degrees.
Old Jul 1, 2013 | 02:59 PM
georgepink's Avatar
georgepink
Please help me understand this. If I start my bike, flip the switch on, then wait a minute or so after bike is parked and switch it off, how will heat damage them anymore than if the auto switch waited until the bike was hotter to kick on?
I bought the switch with the intention of using it, but thought that keeping the heads cool would be a better scenario than waiting until they come up to 190 degrees. If not, i'll install that switch tonight, I know it's a breeze to put in.
