And there is actually a very scientific reason that beary speaks the truth. I'm not going to waste anyone's time explaining it, because most already have a set opinion, and aren't willing to listen.
Beary speaks the truth regarding HIS bike. If he spoke the 'truth' for synthetic oils in general we would all experience the same weeping phenomena as his.
I too have had certain engines, both motorcycle and auto, that did as his bike is doing with syn oil....weeping at the gaskets. Changing to dino sometimes, but not always cured the problem.
So, making a statement that syn causes weeping is inaccurate at best.
And if you're simply going to reply at least provide a link for those of us that have open minds. Otherwise don't waste my time with your post, thank you. But maybe you did it jus2anoyme (and you did).
On a molecular level, synthetic molecules are all the same size. All very small, which backs up the claims that synthetic flows better and lubricates better due to its uniform small molecular structure.
Conventional oil, due to its 'non man made' composition, it is a crude by product that is refined to the point that it meets sae criteria and is still profitable for the oil company. It's molecular structure varies widely. Large molecules, small molecules and everything in between. 'No two the same' could apply here.
Syn oil is genetically designed to be a clean pure oil. It does not 'cook down' into another state. It's structurally the same from start to finish. It changes very little from the day it's poured in, to the day it's drained out. Only it's contaminants bear a factor in its change. the oil itself remains relatively unchanged.
Conventional oil is PROVEN to change composition during its life. It starts at a specific grade, thins out as its additive package is consumed, and then thickens back up as its service life is stretched beyond its intent. It also contains many components that the oil company cannot afford to remove. These components 'cook out' of the suspension over time thus leaving behind a 'coating' inside your engine. Mind you, this takes a lot of heat cycles and a lot of miles.
Syn has small molecules and no 'by products' to slow an oil leak or seep. Conventional have variable sized molecules and by products that get left behind that can collect at seams and joints to inhibit leaks and seeps.
Make sense?
And no, I'm not here to 'anoyu' but I am here 'jus2anoy some'
LOL you can't change facts. I sit and wonder why folks can't accept reality, is it personal?
My engine case DID NOT weep with dino oil. My case DID weep when I switched Syn oil. My case QUIT weeping when I switched back to dino. It STARTED weeping again when I went back to Syn oil.
Folks have no problem accepting that syn oil runs cooler, but won't acknowlege the make up of syn oil might also be the cause of weeping. Does that make sense?
The facts are the facts. So it's not a matter of if, but why. My guess is the molecular structure of syn oil is smaller. And maybe the gaskets become brittle in the Oklahoma heat, I don't know. The bike was four years old with around 15000 miles when I switched. Is age a factor, four years old isn't very old. Is 15000 miles a factor? Maybe, but a lot of folks who switched with around that many miles don't have weeping. So maybe not. It is something though because the engine only weeps with synthetic.
Beary
Beary
Personal?? Pretty much though I explained the mechanical part of the gasket and the FP did say his dealer tighten the cover bolt 1/4 turn, so there was a gap and it leaked. With a 1/4 turn loose bolt, Dino oil would probably leak. If the gaskets are right, SYN will not leak. Not saying SYN or mean to say SYN may not be more prone to leak. What surprise me is the fact that thick hypnoid 90 weight gear lube seem to me to be able to get out of anything. Just were was your motor leaking with SYN? Do you do your own service. Only reason I ask is you say the case which does not have a gasket, but is actually glued metal to metal with a harden sealer. Different temperatures and runs could affect that if it had a broken area in that seal. Unless you do you own service and know, it's real easy to get oil trapped in odd places when you change the filter and they will look like they are leaking for a long while. Just saying. But I am sure you could very well be correct that SYN can leak out of smaller gaps, especially shaft seals. However, I do not consider slight weaping unless it drips from a shaft seal to be a leak. If you have oil coming from the case split, you have a broken seal area. If you search Soft02 post on his engine, you will see an area Harley left open by bad machining on this seal area.
The only way to know what any oil is doing in your bike is to have it sent to a lab to be tested. Check out http://www.blackstone-labs.com. I've used mobile 1 in a lot of bikes and can go more than 10K miles. I change my oil at 10K for piece of mind.
PersonalJust were was your motor leaking with SYN? Do you do your own service. Only reason I ask is you say the case, and unless you do you own service and know, it's real easy to get oil trapped in odd places when you change the filter and they will look like they are leaking for a long while. Just saying. But I am sure you could very well be correct that SYN can leak out of smaller gaps, especially shaft seals. However, I do not consider slight weaping unless it drips from a shaft seal to be a leak.
I agree that weeping is not a leak. I wouldn't have any oil on my finger after running it across the weeping gasket. The oil bled onto the black cause paint which made it unsightly at worst. The gasket that weeped was where the case split and it weeped all the way around that I could see. It was the only gasket. Not even the rocker boxes leaked. While I don't work as one anymore, I am a licensed aircraft mechanic, so I kind of know my way around engines. I am also humble enough to admit to a different source of the oil if it was ever pointed out.
I know that my bike is unusual, so I'm curious to the cause of the weeping. It's hard to have an open minded discussion on this forum.
O.K. Short question. Am I better off changing oil every 2,500 miles, or changing Synthetic every 5,000 miles?
Even. I would say no advantage either way. I run conventional because it's quieter and cheaper. If your engine isn't noisy, then conventional is only cheaper. I think you would need to stretch that syn drain interval to 8 or 10k to even out the cost. If you change syn at 5k,you are protecting your engine nicely, but you aren't enjoying the (claimed) benefit of extended drains.
Given the exact scenario that you pose, I would run the conventional oil and never give it another thought!
