Another oil versus Synthetic question
Given the exact scenario that you pose, I would run the conventional oil and never give it another thought!
Beary
This is why a long-distance high-milage motor can log several hundred thousand miles and still be in great condition. Versus the "little old ladies" car that goes 3 blocks across town twice a week for 20 years with 15,000 miles on it.
The little old ladies motor will be in worse condition at 15k than the one with 300,000 miles on the open highway.
The conditions it operating under are a huge factor in all this. Those contaminants and moisture build up in the crank-case of grandma's car because it never even gets hot, hence contaminants cause corrosion, etc.
My bike logs 2,000-3,000 miles a month (rarely less than 100 miles every time it leaves the garage). It will run up into the 100's of thousands of miles under these conditions. Under these conditions for MY bike a 5k interval with dino or even 8-10k with full synthetic is no problem.
Granny needs to change oil every 3 months regardless of mileage under the short-trip scenario described above.
My engine case DID NOT weep with dino oil. My case DID weep when I switched Syn oil. My case QUIT weeping when I switched back to dino. It STARTED weeping again when I went back to Syn oil.
Folks have no problem accepting that syn oil runs cooler, but won't acknowlege the make up of syn oil might also be the cause of weeping. Does that make sense?
The facts are the facts. So it's not a matter of if, but why. My guess is the molecular structure of syn oil is smaller. And maybe the gaskets become brittle in the Oklahoma heat, I don't know. The bike was four years old with around 15000 miles when I switched. Is age a factor, four years old isn't very old. Is 15000 miles a factor? Maybe, but a lot of folks who switched with around that many miles don't have weeping. So maybe not. It is something though because the engine only weeps with synthetic.
Beary
Beary
Please note that this post is not an endorsement for synthetics as I realize that there is absolutely nothing wrong with running regular oil.
Conventional oil, due to its 'non man made' composition, it is a crude by product that is refined to the point that it meets sae criteria and is still profitable for the oil company. It's molecular structure varies widely. Large molecules, small molecules and everything in between. 'No two the same' could apply here.
Syn oil is genetically designed to be a clean pure oil. It does not 'cook down' into another state. It's structurally the same from start to finish. It changes very little from the day it's poured in, to the day it's drained out. Only it's contaminants bear a factor in its change. the oil itself remains relatively unchanged.
Conventional oil is PROVEN to change composition during its life. It starts at a specific grade, thins out as its additive package is consumed, and then thickens back up as its service life is stretched beyond its intent. It also contains many components that the oil company cannot afford to remove. These components 'cook out' of the suspension over time thus leaving behind a 'coating' inside your engine. Mind you, this takes a lot of heat cycles and a lot of miles.
Syn has small molecules and no 'by products' to slow an oil leak or seep. Conventional have variable sized molecules and by products that get left behind that can collect at seams and joints to inhibit leaks and seeps.
Perfectly put!
