Front fender script clips removal...
Old Jul 1, 2013 | 03:48 PM
iglideUC's Avatar
iglideUC
Default Front fender script clips removal...
There are three clips per side on the inside of the front fender that hold the script emblem on the fender. Can someone suggest a method to get them off so i can pull the script off. I see that the scripts do not have adhesive backing and are only held on with the these clips.
Old Jul 2, 2013 | 01:52 AM
BikerPaul's Avatar
BikerPaul
Pry, carefully and with a small screwdriver. The clips are curved when free, so there is a space under the clip where you can get the screwdriver blade in. Be gentle, and the clips are reuasable.
Old Jul 2, 2013 | 06:52 AM
Gunnysgt's Avatar
Gunnysgt
I agree, removed many of them. carefully pry with a small flat blade screwdriver or similar. When you clear the curved part you can also screw them off like a lid.
Old Jul 2, 2013 | 08:54 AM
RaceFace's Avatar
RaceFace
I got them started with a screwdriver and then once the clips were away from the fender, I used pliers and slowly turned and pulled at the same time. Piece of cake!
Old Jul 2, 2013 | 01:34 PM
iglideUC's Avatar
iglideUC
Copy that! and thanks for the info. Will remove them tonight.
amberwhiskey7250
2014-2024 Touring Models
Sep 13, 2018 07:30 PM
SOA
May 9, 2018 06:42 PM
rchays57
Apr 1, 2017 06:22 PM
LoBoT
General Topics/Tech Tips
Jul 10, 2012 12:55 AM
English Pete
Jan 29, 2010 05:31 PM
