Help diagnose an issue
Old Jul 2, 2013 | 10:50 AM
chgofirefighter's Avatar
chgofirefighter
Default Help diagnose an issue
This is not an issue w my bike, however with one of my riding buddies who has a lil language barrier. He has a deuce, when he rides the bikes shuts off, sometimes you can hear the bike high idling. He says that he tries to maintain a high idle in order to avoid the bike from shutting off.
Trying to help the guy out so I'm looking for suggestions, guidance to see if I can diagnose the issue and get it resolved. Don't want the guy to have an accident on the roads, its unsafe to ride bike that shuts off unknowingly..
I think his bike is an 06 Deuce, its fuel injected not carb...
Thanks for the assistance~
Old Jul 2, 2013 | 10:56 AM
jus2anoyu's Avatar
jus2anoyu
when it shuts off, if you turn the ignition back on with the run switch in run, is the check engine light on?
Old Jul 2, 2013 | 11:36 AM
Hogpro's Avatar
Hogpro
Former Sponsor
Spray throttle body cleaner into the IAC port.
Old Jul 2, 2013 | 11:57 AM
chgofirefighter
Not sure, however, he has to turn the ignition off/on to restart the bike. I will inquire w him about that question..
Old Jul 2, 2013 | 11:58 AM
chgofirefighter
The dirty intake port can cause that problem? Strange but thanks for the suggestion
Old Jul 2, 2013 | 12:37 PM
Captain Itch's Avatar
Captain Itch
Sponsor
I would bet this is his trouble as well..I cleaned mine 3-4 times and the problem went away..
__________________
www.Captain-Itch.com
Old Jul 2, 2013 | 12:58 PM
checkers's Avatar
checkers
Clean and tighten battery cables before doing anything else.
Old Jul 2, 2013 | 02:31 PM
Fatboy Brian's Avatar
Fatboy Brian
Same problem on my 06 King, this took care of it.
Old Jul 2, 2013 | 03:09 PM
jus2anoyu's Avatar
jus2anoyu
I had a similar issue but the cause was a poor connection in the run/stop switch. It made enough connection to run, but wasn't powering up at full voltage. The bike would stall if I rolled completely off the throttle. I noticed that when I turned on the ignition, my cel wasn't on. I then cycled the run/stop switch several times and it came on. I haven't touched the run/stop switch since and all has been fine. The idle air port is a high probability as well, but in my case, I run a half a can of seafoam or tecron through the upper engine at every oil change so that wouldn't be an issue for me.
Old Jul 2, 2013 | 03:12 PM
HTNHARD's Avatar
HTNHARD
Where is the IAC port?
