HP TQ
Old Feb 27, 2007 | 07:35 PM
DR.Greenthumb's Avatar
DR.Greenthumb
Default RE: HP TQ
I've got a buddy with an 07 Street Glide.His #'s with similar mods as yours are.
72.70 HP
85.65 Torque Before a dyno tune
76.62 Hp
89.43 Torque After a dyno tune
Old Feb 27, 2007 | 08:15 PM
kingultra's Avatar
kingultra
Default RE: HP TQ
79.?hp and 98.? tq on mine - Pc111, k and N air, and v and H oval slip ons
Old Feb 27, 2007 | 08:31 PM
Gutman's Avatar
Gutman
Default RE: HP TQ
This is what I got.
Stock 07 FLHX = 62.51 hp and 79.48 pounds feet.
SE slip-on's and a/c 70.16 hp and 80.72 pounds feet.
SE slip-on's, a/c and Fulsac 75.7 hp and 86.41 pounds feet.
Rinehart true duals SE a/c 77.85 hp and 92.07 pounds feet.
All runs on same '07 FLHX, Dynojet 250i correction between 1.02-1.03, 80.69-84.88 deg f, 29.42-29.84 in-HG.
All runs were pretty consistant.
As for the drop in power at lower RPM with Rineharts? I haven't seen that. Hope it helps.
Old Feb 27, 2007 | 09:14 PM
crp5's Avatar
crp5
Default RE: HP TQ
Wow, I must have really gotten screwed. Had my bike tuned at Harley of Atlanta with RH True Duels, SERT and Stage 1 filter mod and only got 83 peak torque and 71 peakhp. I do have my dyno sheet, but can't scan/post. What should I be looking at to see if it was tuned properly? Has anyone else had +/- experience with Atlanta HD?
Old Feb 27, 2007 | 09:49 PM
Longtimegone's Avatar
Longtimegone
Default RE: HP TQ
crp5, if you are talking a 88, you're right in the ballpark on those numbers. A 96 should be higher.
Old Feb 27, 2007 | 10:27 PM
jrudicel's Avatar
jrudicel
Default RE: HP TQ
Anyone want to look at my dyno sheet from a few days ago? Kinda curious about the smoothing , correction,etc.. What effects do these things have on the results etc? Wanting to learn as I go here. Also curious if you can have a good looking sheet and numbers, but it still not be quite right with the timing and things you cant see? Or is it something that if it looks good on paper, it is good? By the way, its an 06 SG with RH true duals, Big sucker AC, and SERT. 1 hour on the dyno and cost 65.00 for them to tune it... Reading the SERT manual as we speak as well.... lol
http://i169.photobucket.com/albums/u.../06SG_Dyno.jpg
Old Feb 27, 2007 | 11:18 PM
Easyglide's Avatar
Easyglide
Default RE: HP TQ
I had the SE One piece Street Performance Mufflers and the Stage One done.
HP Before 67.71 After 75.12
TQ Before 82.36 After84.75
For the type of riding I do, this cuts it for me.
Old Feb 27, 2007 | 11:40 PM
johnny canuck's Avatar
johnny canuck
Default RE: HP TQ
your weakest link is the exhaust package...suggest V&N Ovals or V&H basic slip ons...they flow better than SE on the factory headers...did your dealer install map 78?..I think you got a canned map and no fine tuning...duyo was a waste of time & money
Old Feb 28, 2007 | 08:30 AM
crp5's Avatar
crp5
Default RE: HP TQ
ORIGINAL: Longtimegone
Running a 96 in an 07 Ultra. Thought it should have been higher, but didn't have a solid reference pointuntil the post.
Damn...damn....damn... looks like I need to find a good tuner locally.
Old Feb 28, 2007 | 10:02 AM
geargrinder's Avatar
geargrinder
Default RE: HP TQ
ORIGINAL: jrudicel
Everything looks good, I personally like to see SAE correction used and smoothing 5, but this is OK. Youratmospheric correctionwasSTD, and your smoothing was 2. Let's say that you are comparing to someone's graph that usedtoday's more common correction of SAE and smoothing of 5, your numbersare approx 5-6% higher.The most importantthing hereis that your dyno operator did use a correction for atmospheric conditionssoif you ever go back, as long as the same dynosetup is used, you can compare to your previous pulls. But as you can see here,what correctionsystem was used, if any, and smoothing numberscan affect the results dramaticallymaking comparing numbers from dyno to dynosomewhat difficult unless you understand dynos. It even gets more difficult in the automotive chassis dyno world because many brands of chassisdynos are popular and the DynoJet brandusuallyreads 10-15% higher then the other brands, sowhen stating car dyno numbers, we have to state what brand of dyno also.
In my opinion, your HP curve looks good, no powerdips or bulgesmeaning that your combination is working well across the RPM spectrum at wide open throttle. Your A/Flooks good,would not want it any more lean in a few places.
