Broken Belt... AGAIN!
Old Jul 15, 2013 | 12:24 AM
sbergerson's Avatar
sbergerson
Default Broken Belt... AGAIN!
A month ago, my wife took her 2004 XL to a friends house for a few days. She parked it and spent time visiting. When she started the bike to head home and shifted into gear, the bike just revved up and didn't move. She looks down to see her belt lying on the driveway. It had a perfectly straight cut across with no visible damage. Her bike only as 22,000 miles and we decided that some low life P.O.S. vandal cut the belt with a knife while it was parked outside for three days. I changed it, and things are good... Until today.
Put my 2003 Road King Classic with 69,000 miles in the garage yesterday. Everything was fine. Started it up today, put it in gear and it only revved up and didn't move. I look down and find MY belt lying on the floor of the garage! No stone chips or holes, but there is wear on every tooth. The rear pulley is also worn on every tooth. It's round on the forward side of the teeth, but on the rearward side of the teeth, they are all worn at an angle rather than round.
Compared to the wife's Sporty, this thing is a nightmare. Pulled the bags, exhaust, rear wheel, shifter, swing arm, primary cover, clutch, sprockets, and primary case.
I ordered a new belt and rear pulley. The transmission pulley looks good, but I'm wondering with all the labor in tearing this down if I should replace the trans pulley even though it looks OK?
Also, there was a lot of oil and dirt on and around my trans pulley. Do I need a new seal?
Finally, do you have any ideas why I lost a belt? We do live on a dirt road (about 2 miles)...
Any input would be appreciated.
Old Jul 15, 2013 | 12:48 AM
Arizona's Avatar
Arizona
Hers sounds like a vandalism.
Yours at 69k is a bit premature, but the dirt road probably adds some wear to it. The teeth worn how they are makes me wonder if maybe the belt tension wasnt correct, causing wear and a breakage.
At least it happened at home and not out of town.
Old Jul 15, 2013 | 08:28 AM
grbrown's Avatar
grbrown
Other than stone damage the most common reason for belt breakage is incorrect tension. I've had four belt drive Milwaukee bikes and only one belt damaged by a sharp stone to date. Take a deep breath, prey to all your gods, fix it and ride - life will soon feel fine once again!
Old Jul 15, 2013 | 09:43 AM
bagman1's Avatar
bagman1
I agree with this. I believe your wife's belt failed from being too tight not vandalism. The straight cut is the sign of a clean break.
Old Jul 15, 2013 | 09:56 AM
Griff012FLHX's Avatar
Griff012FLHX
Good time to decide if ya want a 30t pulley....
Old Jul 15, 2013 | 10:00 AM
bagman1's Avatar
bagman1
Don't mean to hi jack here but can the stock belt on an 07 be used with a 30 T sprocket?
Old Jul 16, 2013 | 09:37 AM
sbergerson's Avatar
sbergerson
I never realized how involved changing a belt is on a touring model. Sportster was much easier.
I have uploaded a pic of my rear pulley. You can see the extreme wear on the tension side of every tooth (left side in photo), while the slack side of the teeth are nice and round.
I use the belt tensioner tool, I thought my tension was alright, but I'll make sure this time. Do I need to recheck tension after running a new belt for a while?
Attached Thumbnails Broken Belt... AGAIN!-img_0468.jpg   Broken Belt... AGAIN!-img_0469.jpg
Old Jul 16, 2013 | 09:50 AM
Guntoter's Avatar
Guntoter
I don't believe that wear is from the belt slipping, I believe that is from friction most likely caused by grit and other foreign substances in between the belt and pulley. Was your lower belt guard in place? If not make sure you get one in there. I am guessing the rear pulley is made of softer metal than the drive pulley which is why the rear is so worn. If the drive pulley does not show any ground out teeth, it may be OK to re-use as those pulleys are a bit of a pain to get off since H-D loctites the nut. Otherwise if it has any wear at all, change it so it does not repeat what you have right now. If you do re-use, clean it real good with very hot soapy water to make sure no grit is left on it.
If you do decide to pull the sprocket, here is a place to get the tools you will need. You will need the mainshaft bearing race tool, mainshaft sprocket wrench and the trans sprocket locking tool. They have other tools on there is you need to change the main seal on the transmission. Most likely the leak you are having is from the seal on the inner primary case. If the race on the mainshaft is grooved, you will need to replace that also. http://georges-garage.com/trans_pre_o7.htm
Old Jul 16, 2013 | 12:15 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
According to the Gates manual on these belts, that's an under tension symptom. "When a belt is too loose for the design load, the belt teeth try to climb the sides of the sprocket grooves, which dramatically increases the stresses on the belt, the belt teeth and the shafts and bearings, leading to rapid tooth wear and reduced component life."
Old Jul 16, 2013 | 12:50 PM
checkers's Avatar
checkers
Do not power wash in that area.
