Need Power vision base map for unique build, kinda.
Old Jul 16, 2013 | 08:34 PM
BlackPearl#1's Avatar
BlackPearl#1
Default Need Power vision base map for unique build, kinda.
Working with the guys at FM and I want to purchase the PV. My build is an 08 Ultra, but I put the HD head pipes on from an 09 to have the 2-1-2 set up. I am using 4 inch CVO mufflers with Fullsac 2 inch baffles and an Arlen Ness big sucker. Everything else is bone stock. If anyone has a good place to start I would greatly appreciate it. Brian says he can get pretty close, but has not had this set up yet. Any help is greatly appreciated.
EDIT: Stock o2 sensors.
Email is wards2530 @ gmail . com
Kris
Old Jul 16, 2013 | 08:53 PM
Pioneer74's Avatar
Pioneer74
Use his MAP that will get you close then do some auto tune runs and dial it in.
Old Jul 16, 2013 | 09:07 PM
ke5rbd's Avatar
ke5rbd
Kris
Send me a pm with your email and I will send you one I am running. Same same. It is too large to attach as a .zip.
Old Jul 16, 2013 | 09:15 PM
iclick's Avatar
iclick
Flasht any tune that will allow the bike to run, then do multiple tuning runs through the entire operating range with the PV. Of course a starting point that more closely fits the configuration of the bike is preferable.
Old Jul 16, 2013 | 10:15 PM
rockajet1's Avatar
rockajet1
+1 on that. I did my build (all from Fuel Moto) as noted in my signature. The map was for Fuel Moto's head pipe and slip ons. The only difference was I started w/ V&H Monster Ovals and decatted stock pipes. Brian said that map would be fine for my build after some autotune runs. Note: I do have the AutoTune wide band set up. Then I switched to Supertrapp Fatshots and requested a new map from FM. They sent me the exact same map with a different ID. The bike ran very well from the get go both times and after three or four AutoTune runs, I cannot imagine the bike running any better. Reasonable fuel mileage. No decal pop. Great performance.
Neggy ZRXOA 5248
14
Mar 3, 2015 06:56 AM
chi45cken
Aug 1, 2014 03:37 PM
buttmonkey
Jun 29, 2014 10:48 AM
Notz
Apr 22, 2013 10:50 AM
20FXST06
Feb 15, 2012 04:35 PM
