Break in question for big bore
Old Jul 17, 2013 | 08:40 AM
ftworthcowboy's Avatar
ftworthcowboy
Ride it hard and do first oil change at 500 miles.
Old Jul 17, 2013 | 08:55 AM
my67pnycar's Avatar
my67pnycar
Originally Posted by HDV-GLIDE
60mph in 3rd gear with new engine parts huh.......I guess if somethings going to let go, it will doing that.....
Like someone else stated, contact the business who made/sold you the kit and follow their recommendations....
OP stated his mechanic said it was broke in to soft. This is from the mototuneusa site as suggested in one of the posts above
http://www.mototuneusa.com/break_in_secrets.htm
The best method is to alternate between short bursts of hard acceleration and deceleration.
If something is gonna let go, its gonna sling apart breaking it in normal also. 30-60-30x10 link from the forums. Lots of riders break theirs in like this.
https://www.hdforums.com/forum/engin...-big-twin.html
https://www.hdforums.com/forum/touri...-break-in.html
You break your bike in how you like, I broke mine in like this, 8000 miles so far no problems except the air cleaner plug limp mode deal (knocking on wood)
Old Jul 17, 2013 | 09:18 AM
johnd5412's Avatar
johnd5412
Yep, that's how I broke my S&S 106 kit in (the motorman way). It runs like a beast...
Old Jul 17, 2013 | 09:49 AM
TUCCI's Avatar
TUCCI
I was beginning to think I had a suspicious nature cuz I was saying BS to myself when I read the response from the indy.
Old Jul 17, 2013 | 09:55 AM
Harleycruiser's Avatar
Harleycruiser
Originally Posted by $tonecold
I agree with this to the extentand do a leak down or doesn't have the equipment to do it, I would suggest you find a different mechanic. Sumping is usually caused by the oil pump failing to scavenge the crankcase. Could be something as simple as a bad o-ring on your return.
Yep I wonder if he went into the cam case, could be a missing o ring
Otherwise trashed pump charging double for his mistake
Op what are the symptoms?
Old Jul 17, 2013 | 10:27 AM
goofey's Avatar
goofey
Thanks for the info.He did look at o ring and oil pump and they were ok. Seen oil on top of pistons is why he is thinking rings were not sealed. Think I will look at ss web site for break in info been riding 45 years and lots of bikes never had a break in problem before. Thanks again.
Old Jul 17, 2013 | 10:36 AM
grbrown's Avatar
grbrown
Wink
Click on the link I gave earlier!
Old Jul 17, 2013 | 10:49 AM
beary's Avatar
beary
The thing about ring breakin is that its 90% done within the first 50 miles, probably more like 30 miles. So you can check the compressions at 100 miles and know if they broke in or not.
Beary
Old Jul 17, 2013 | 11:01 AM
Harleycruiser
Oil on top of the piston is not oil scavaging, you have oil blow by.
Big difference.
What kind of rings? Cast, Molly?
Is it bad enough to foul the plugs
Old Jul 17, 2013 | 11:25 AM
hog95023's Avatar
hog95023
Break it in on the dyno.
