Difference between cams?
Old Jul 18, 2013 | 08:20 AM
MyClassic09's Avatar
MyClassic09
Default Difference between cams?
I would like to know power diff between two cams power rpms...
1. EV27 .495/.495 .182/.166
2 SE-3 .503/.503 .185/.169
all the other parameters are the same except the lift numbers so curious as to which is better for a tour bike...both should be direct bolt in...
Old Jul 18, 2013 | 08:38 AM
Leftcoaster's Avatar
Leftcoaster
I used the EV27 in my '95 EGC (it's still in there). It works well and has much better pull in the mid-range. Didn't have to downshift to pass any longer.
Don't know much about the SE-3 but on a basically stock motor it looks like there would be little difference between the two.
Old Jul 18, 2013 | 09:01 AM
0ldhippie's Avatar
0ldhippie
They are identical except for a very little more lift in the SE-3. The EV27 was the "go to" cam for Evo touring bikes and the SE-3 is a copy. You aren't gonna tell a difference between them.
Old Jul 18, 2013 | 09:25 AM
MyClassic09
sweet...I found a good deal on the SE-3 as it comes with other parts for my evo..so wanted to make sure...
moose545
Feb 2, 2018 05:50 AM
Eastcoast Jim
Evo Era Parts
Sep 28, 2017 10:19 PM
fxd666
Engine Mechanical Topics
Apr 24, 2015 09:54 AM
magnum629c
Oct 6, 2012 02:42 PM
skulznflames
Exhaust System Topics
15
Nov 28, 2008 04:46 PM
