JIMS Vacuum Fed Fork Filling Tool
Old Jul 21, 2013 | 10:22 AM
Hausguy's Avatar
Hausguy
Simple and effective. I like it.
Old Jul 21, 2013 | 10:36 AM
senna's Avatar
senna
Originally Posted by Lowcountry Joe
You don't use a jack, do it on the jiffy. Remember you have to hold the front brake and pump the front forks up and down during the process. So that should tell you that you don't put the front wheel in the air.
You must remember that HD thrives on service dollars, which equates to time and materials consumed in their shop. Their are numerous examples of procedures in the service manual where many of the extra steps they list can be avoided while still performing a successful and quality service. Thing is, the HD techs skip those steps too, but they still charge you for the time it would have taken them to do the job had they followed all the steps.
You know, I have to give props to lowcountryjoe. His posts, unlike the ones some people post that just seem like they just like to hear them selves talk (type). Joe always has well thought out, factually based common sense advise. Joe, it very thought full of you to contribute quality and help full information.
There are a few others I have noticed as well, Dawg and ultrantz comes to mind .
p.s. I do not mean to high jack the thread.
Old Jul 21, 2013 | 12:19 PM
Hausguy's Avatar
Hausguy
Hey Lowcountry Joe - sorry to trouble you but one question to clarify things as I'm looking at the service manual. You said to replace the O-Ring under the cap screw. Do you mean the "Quad Ring Seal"? According to my diagram, the order is 1) Cap bolt, 2) Quad Ring Seal, 3) Fork tube plug, and 4) O-Ring,. 5) spring. Since the Fork tube plug is under pressure, I assume that we're not replacing the O-Ring or are we? Thanks again!
Old Jul 21, 2013 | 01:31 PM
zdrifter's Avatar
zdrifter
Originally Posted by fullautomike
Has anyone used one of these? Tool I love tools, but do you think it is worth the money to save some time and work? Plus I'd love to put some heavier oil in my forks.
http://iwblogger.com/2013/jims-vacuu...-filling-tool/
Retail is $219, I'm still thinking of getting one
As others have said props to LowcountryJoe for the detail on Fork Oil change, however the device mentioned by the OP allows you to do the change without accessing the top of the forks and thus with much less effort. The key elements are the three way valve and the MityVac.
Seems pretty easy to create this device at home for ...way... less than $219 (the $219 does not include the MityVac) and honestly I think every HD owner should have a MityVac anyway. Have had one for a long time and used it for countless things. Take a look at the picture of the device and how to use it (and how to make one similar) should be evident. If it's not you probably should let someone else do it ... Cheers
Old Jul 21, 2013 | 02:10 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Yes. My nomenclature was a little off. The service manual calls it the quad ring seal. The parts manual calls it a just plain "oil seal". It is part number 45733-48. Like a lot of parts, I believe it could be re-used because it is fairly pliable and thick. However, having some chicken blood in my veins, and knowing that this oil seal needs to keep the top end of the fork air tight, I went with new ones. They are not expensive as I recall. Stick them in and torque the fork cap bolt to 60-70 ft lbs.
By the way, you can use any copper washer you can find that will fit around the screw. I had to get mine at an autoparts place because the HD dealership did not have any in stock. I couldn't believe that. But what that also tells me is if they had to perform a fork oil change, they probably would re-use the copper washer. In fact, I reused mine after I took a look at them and have had no leaks. Just make sure the area that will be under the washer is very clean before you install the screw and tighten to torque spec of 72-96 inch pounds.
I am glad to help when I can. I have received and continue to receive a lot of helpful info from the guys on this forum. So if I have personal experience with a project, I am prone to throw in my two cents.
Old Jul 21, 2013 | 06:10 PM
MNPGRider's Avatar
MNPGRider
Can't help but notice an ad for a vacuum cleaner is on the side of my screen. Probably because "vacuum pump" is mentioned in this thread!
Thanks for the tips.
Old Jul 21, 2013 | 08:36 PM
fullautomike's Avatar
fullautomike
Awesome Lowcoounty Joe! Thanks. For some reason I thought the fork cap bolt held the spring under pressure, I think my 1988 Sporty was like that. I looked at my service manual after reading your post. I'm going to get the low profile socket and ignition tool and change my oil at my 10k service. What weight did you put in and would you use it again?
Thanks again!!!
What? You don't take the forks off to perform a fork oil change. You don't need fancy vacuum devices either.
Here are the steps I took:
-Have a service manual handy
-Have the right tools (low profile 36mm socket..avail for $16 and a switch alignment tool) You can get by without either, but like I said..the right tools
Here is a pic of both of these tools:
-Have a replacement copper washer to go under the head of the drain screw
-Have a replacement oring for under the 36mm cap screws
-Remove the ignition switch stem
-Remove the inner faring cap. Now the top fork 36mm heads are accessible
-Remove the drain screw down low and in the rear of each leg
-Remove 36mm cap screw to allow all fluid to drain
-Pump forks a few times to ensure all fluid is out
-Reinstall fork leg screw with new copper washer to torque spec
-Fill from the top with 11 oz of your choice of fork oil, pumping a little as you go, easy pumps, nothing drastic
-Install new orings and torque 36mm cap screw to spec
-Reinstall inner faring cap and switch stem
-Take a picture of your old fork oil and post it here on the forum!
Mine looked like this at about 15K:
Old Jul 21, 2013 | 08:55 PM
dawg's Avatar
dawg
If you go to HD they will try and sell you the fork drain screws with the washers, pn#45858-77. They used to sell the washers separately, pn#45708-99 from the chrome drain screw kit, but now they obsoleted them and make you buy the screws and washers. Best to grab the washers and mic them and then buy in bulk from somewhere like McMaster Carr. http://www.mcmaster.com/#copper-sealing-washers/=nq41mm
Old Jul 21, 2013 | 09:02 PM
voodoodrug's Avatar
voodoodrug
I used the rear axle flat wrench in the harley tool kit that came with the bike,works perfect, and a screw driver for the ignition.Note on ignitionut a flash light under ignition cause theres a hole on the bottom which lets light in to see ignition keys better.you can find a lot of short cuts not in the manuel or the web.
Old Jul 21, 2013 | 10:36 PM
Lowcountry Joe
Thanks again!!!
Nothing is going to jump out at you when you remove the cap bolt. So you will be fine.
I used Amsoil Shock Therapy Medium 10 wt. You can see the bottom half of the container in one of the pictures. I may try the heavy duty Shock Therapy on the next change. I do like the action of the front end now, especially how it handles speed bumps and track crossings. So for now I am satisfied. Nice thing is that it's easy to change the oil to something else and give it a try. You are only talking about 22 ounces total anyway for both forks.
Some guys even combine different weights to get a custom feel in their front end suspension.
